heater box #1364666
01/05/13 01:36 PM
01/05/13 01:36 PM
indy
70moparmike Offline OP
indy
i have a 69 b body heater box, non a/c. i am restoring it and the fiberglass has duct tape residue looks like on it. is there something to use to get it off without takeing the surface off anymore than it has deteriorated already? and what do you refinish the box with? thanks for the info as always.
Re: heater box [Re: 70moparmike] #1364667
01/05/13 02:26 PM
01/05/13 02:26 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Simple Green. Then fine rubbing compound will clean them up to fresh looking.
Test cleaners are compounds on the back side of the box to experiment with first.
Re: heater box [Re: autoxcuda] #1364668
01/05/13 02:46 PM
01/05/13 02:46 PM
indy
indy
outside of the box is pretty rough? like the gelcoat is about gone. has little fibers showing though. anybody on refinishing the finish on the box? and what products to use? thanks moparts
Re: heater box [Re: 70moparmike] #1364669
01/05/13 05:47 PM
01/05/13 05:47 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
Full Circle Restoration makes a kit to refinish the plastic. I used it on my airgrabber box and looks good!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: heater box [Re: JMCFAN] #1364670
01/05/13 07:17 PM
01/05/13 07:17 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
http://www.restorationfullcircle.com/
I've never used it, just when I googled it took a while to find it. I need to fix a couple breaks in mine also.
Re: heater box [Re: 68KillerBee] #1364671
01/05/13 08:15 PM
01/05/13 08:15 PM
New Mexico
New Mexico
Cant vouch for the repair kit... but the finsh kit works pretty good.
Re: heater box [Re: JMCFAN] #1364672
01/06/13 09:20 AM
01/06/13 09:20 AM
indy
indy
i have the kit for my airgrabber, but i don't think it will take care of the fibers protruding from the surface of the box? should i lay the paint on in thick coats and sand back down?
Re: heater box [Re: 70moparmike] #1364673
01/06/13 08:16 PM
01/06/13 08:16 PM
New Mexico
New Mexico
I would try it on the back of the box...thats not visable. only way to know.
