A BODY E BRAKE HANDLE ISSUES #1364490
01/05/13 12:11 AM
01/05/13 12:11 AM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
Does someone out there have a pic out of a manual or under the dash of where everything goes for the e brake handle assembly on my 70 dart. i have it in there i just cant figure out where the one bolt goes???
Thanks for any help
Re: A BODY E BRAKE HANDLE ISSUES [Re: BIGJOE30] #1364491
01/05/13 12:20 AM
01/05/13 12:20 AM
Are you talking about the stud that is pressed into the E brake bracket that attaches through bottom of the dash? If so the stud goes through a hole in the bottom lip of the dash on the left side(drivers) of the steering column. I have a 1969 Dart GTS and a 10971 Duster, I went out and felt up under the dash to see if the Dart had one or two studs, it feels like one stud and a special nut with a captured washer that holds the stud into the dash I could take a picture of it in the morning, PM if you want that, I will need your Email address to send the pictures to.I guess I could put the picture on this post, huh
Re: A BODY E BRAKE HANDLE ISSUES [Re: Cab_Burge] #1364492
01/07/13 05:32 PM
01/07/13 05:32 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
yes please just reply that would be great!
Re: A BODY E BRAKE HANDLE ISSUES [Re: BIGJOE30] #1364493
01/09/13 07:34 PM
01/09/13 07:34 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's a 69 Barracuda installation.
Re: A BODY E BRAKE HANDLE ISSUES [Re: kentj340] #1364494
01/09/13 07:35 PM
01/09/13 07:35 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Another of 69 Barracuda
Re: A BODY E BRAKE HANDLE ISSUES [Re: kentj340] #1364495
01/09/13 07:38 PM
01/09/13 07:38 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Many more photos of 69 Barracuda park brake factory installation are available, all taken before disassembly for restoration. Holler if you need anything specific.
Re: A BODY E BRAKE HANDLE ISSUES [Re: BIGJOE30] #1364496
01/09/13 08:40 PM
01/09/13 08:40 PM
1971 Duster picture of handle.One more try. It seems like Moparts don't like my attachments now I hope resizing it helps It did
Re: A BODY E BRAKE HANDLE ISSUES [Re: Cab_Burge] #1364497
01/09/13 09:04 PM
01/09/13 09:04 PM
Behind the instrument picture showing the return spring attachment, look closely
Re: A BODY E BRAKE HANDLE ISSUES [Re: Cab_Burge] #1364498
01/10/13 10:40 PM
01/10/13 10:40 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
THANKS ALOT FOR THE HELP GUYS!! I GOT IT FIGURED OUT NOW. NICE PICS!!
