Page 2 of 3 1 2 3
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Guitar Jones] #1364454
01/05/13 01:30 PM
01/05/13 01:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That #2 main bearing lost it's form due to overheating probably from lack of oil judging from the photos.
Heat caused the bearings to loose the crush... it could
be the crank wasnt straight being that its the one
set... but there was dirt in there and it happened
on the first fire up
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364455
01/05/13 02:01 PM
01/05/13 02:01 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
What the experts above said, and don't forget to clean your rocker shafts out with the brushes too.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Bad340fish] #1364456
01/05/13 02:18 PM
01/05/13 02:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A guy that works in my garage behind the house did the same thing!
Love it, that guy screws my stuff up sometimes also lol
You know what I've learned from my mistakes???
It's that I maker lots of mistakes!
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Bad340fish] #1364457
01/05/13 02:40 PM
01/05/13 02:40 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I'm pretty sure thats the same guy that is responsible for this mess as well!
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364458
01/05/13 02:52 PM
01/05/13 02:52 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well we all learn from our mistakes. as a teenager my first motor I nick the crank. would not turn over ! and 20 years ago I did a motor and did't get the crank holes clean I thought the machinist clean it when he was done.never assume . end'ed up with the same mess.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: VernMotor] #1364459
01/05/13 09:31 PM
01/05/13 09:31 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I still remember in the engine building class; the instructor said "clean it, and then clean it again and then when you're done, clean it again.
Yeah, it's got a smallblock.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Performance Only] #1364460
01/05/13 09:41 PM
01/05/13 09:41 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
There's certainly a lot of trash in the bearings, but I think some of you are really overlooking the obvious cause of failure. Take a good close look at the wear pattern on those mains and think about it.
Okay,
Boy , I see lots of stuff.
1. Lots of trash in the oil.
2. Uneven wear patterns.
3. Wear at the parting lines.
4. Heat build up burns from lack of oil.
5. Apparent crank contact on all bearings.
Those are the symptems that I see, so what do they mean.
My guess.
Combined issues,
trash in the oil
main bearing bores out of round
bearing clearences to tight
lack of oil flow at some point
maybe poor assembly with grit on back of bearings
any or all of the above
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Sport440] #1364461
01/05/13 10:09 PM
01/05/13 10:09 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I would just throw the crank back in the block < and run the snot outa it >... Just kidding... drop it back in and dial O the mains and see whats up
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: emarine01] #1364462
01/05/13 10:13 PM
01/05/13 10:13 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Its hard to tell from the pics but I would measure for taper also...
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Sport440] #1364463
01/05/13 10:19 PM
01/05/13 10:19 PM
Delray beach, Florida
P
Performance Only Offline
P
Okay,
My guess.
Combined issues,
trash in the oil
Most everybody just assumes it's a lack of oil. It may or not be. Take a look at the wear pattern on the mains all the way up to the parting line. given that there's at least .003" of ecentricity built into the bearings, that tells me right away there was insufficiant oil clearance. A good portion of the trash may have very well come from the bearings. I'll say this also, when a machinist finishes working on your stuff, they typically clean the worst of the debris from it whether it be a block or a crankshaft or most anything else. They don't clean and prep it for final assembly unless you specifically ask them to do it. That type of cleaning generally comes with an additional charge. It's up to the person assembling the engine to make sure everything is spotless and ready to go.
When you see a bearing into the copper it was either starved for oil or had no oil clearance to start with. Since the rod bearings don't seem to be into the copper, my guess goes back to lack of oil clearance on the mains. It's pretty obvious the heat on that one bearing caused it to lose its temper and it wouldn't surprise me to see a slightly bent crank and signs of bluing as well.
The block needs to be closely inspected and probably align honed or bored again. (I prefer boring over honing)
Just because a block is align-honed and the crank was ground does not mean oil clearance is automatically okay, nothing could be further from the truth, actually.
I have teo engines in the shop right now that look alot like the OP's. One was built by a local machine shop with less than 5000 miles on it and the other by the owner with ZERO miles on it, just cam break in time.
My best advice would be to take nothing for granted when it comes time to put it back together. Enlist the help of a competant machinist to cage the bearings and measure, or at the very least, someone with the right tools and the experience necessary to do the job right. You can't have any engine part too clean, so when you think you got it spotless, clean it again.
Best of luck.
machine shop owner and engine builder
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364464
01/05/13 10:52 PM
01/05/13 10:52 PM
ill
dennismopar73 Offline
ill
Last time seen anything like that, I wore down couple lobes down on a cam??
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Performance Only] #1364465
01/05/13 10:58 PM
01/05/13 10:58 PM
Puyallup, WA
Puyallup, WA
Thanks for all the help in understanding this, guys. I would maintain that if exessive crud got into the bearings, it came from inside the oil galleys, as I did not clean them upon assembly. I did, however make sure that all surfaces were clean, clean, clean. I may have missed something, but I am pretty confident about the cleanliness of my assembly (outside of the oil galleys). The main bearing clearances were measured at .0018 - .0022 with plastiguage. This jived with what the machinist told me he worked to, which was .002. I realize this is a little tight for a race motor, but well within specs for a street motor. It did spin freely by hand on the snout upon install.
In an effort to make sure I check every detail this time, I just purchased some tools online. I have a bore guage indicator, and a set of micrometers on the way. I already have a dial indicator with a magnetic base and a bridge base. I should be tooled up to check every detail this time.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364466
01/05/13 11:01 PM
01/05/13 11:01 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Look on the bright side,,at least nobody blamed the 440 Source parts!!
If you like drag racing, support your local track.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364467
01/05/13 11:13 PM
01/05/13 11:13 PM
On bearing and piston to cylinder wall clearances, looser is always better than a little to tight I like and use .003+ on th rods and mains
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: Cab_Burge] #1364468
01/06/13 12:43 AM
01/06/13 12:43 AM
Washington
SuperStock68Dart Offline
Washington
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: SuperStock68Dart] #1364469
01/06/13 01:40 AM
01/06/13 01:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just glad to see you found it before it got worse and did any more damage. Ron
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: 383man] #1364470
01/06/13 02:24 AM
01/06/13 02:24 AM
Puyallup, WA
Puyallup, WA
Me too, Ron! I may be slow, but I'm learning. I'm very glad I heeded my own better judgement and tore into it when I felt something wasn't right.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364471
01/06/13 04:31 AM
01/06/13 04:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It is also a good feeling when you find and repair your problems yourself. And its even more rewarding when its with a super fine Mopar like yours. Ron
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364472
01/12/13 04:01 AM
01/12/13 04:01 AM
North Carolina
southernman Offline
southernman  Offline
North Carolina
67, sorry to hear about the bottom end failure, but after looking at the pictures you posted, I'd put my money on a bent crank. When the converter ballooned, driving the flex plate bolts into the back of the block, the shock load was transferred through the crank. Resizing the crank to fit the 400 block may have enabled such damage.
As I look at number 4 main (and yes, I realize unmodified oiling can show accelerated wear at this journal - but rarely after just 5K miles is assembled correctly, you can also detect excessive wear in the number 4 journal - relative to the rest. I'd be willing to bet it bent the crank. I don't see anything that suggests a problem with oiling. I think it's the byproduct of a catastrophic converter failure. Just my SWAG, and I may be wrong, but I'd sure like to know how it checks out.
Southernman
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: southernman] #1364473
01/12/13 11:27 PM
01/12/13 11:27 PM
Puyallup, WA
Puyallup, WA
The crank is going to the machine shop Monday where I'll specify it to be checked for straight and magnafluxed. If it checks out okay, I'll have it refinished and then re-assemble. If it has issues, I'll start from scratch, perhaps look at a "source" crank this time.
Page 2 of 3 1 2 3
