Re: Milodon 31580 Road Race Pan Help
[Re: jbc426]
#1363596
03/03/15 01:18 AM
03/03/15 01:18 AM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
Not sure if this info is helpful, but the pan fits in my 1970 e-body with 2 inch TTi's. The scattershield is more of a concern with the pan in my case. The pan has to be installed and the engine put in sans bellhousing and clutch to clear the k-member.
I ran into this exact same problem with my 74 Challenger, small block, 1 3/4 Hookers, and the Milodon road race pan. The pan sump is so freaking big, I couldn't get enough angle with the trans and bell housing in place to get it all wiggled down in between the motor mount blocks.
Once I drop the trans and bell housing, it dropped right in. Its a plenty snug fit, but it doesn't touch anywhere and nothing hits it, although I do have a single header tube within 1/2" on the passenger side.
[Re: TC@HP2]
#1363597
03/03/15 02:21 PM
03/03/15 02:21 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I went from the bottom up in my 68 charger with a 4 speed. No problems except for valve cover hitting the frame. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: lewtot184]
#1363598
03/03/15 09:01 PM
03/03/15 09:01 PM
Posts: 30 Norcal
Wildjones
Norcal
Sorry to dig this up, but can anyone point me in the right direction for something to block off the oil temp sender bung? I'm not certain what the threads are, nor where to look for such a thing?
Thanks!
1/2" pipe plug.
So if I bought something like this http://m.summitracing.com/parts/prs-1020 would I also need an o ring or something to seal? sorry for the rookie question.
[Re: Wildjones]
#1363599
03/03/15 09:19 PM
03/03/15 09:19 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
No, use teflon thread sealant. NPT means National Pipe Tapered, meaning the deeper it is screwed in the tighter it gets. NPS is straight thread and would require a sealing feature like an o-ring or sealing washer.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#1363600
03/03/15 09:53 PM
03/03/15 09:53 PM
Posts: 30 Norcal
Wildjones
Norcal
Awesome explanation, thank you!
