Re: Milodon 31580 Road Race Pan Help
[Re: Beep Beep]
#1363558
01/03/13 11:29 AM
01/03/13 11:29 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Not sure if this info is helpful, but the pan fits in my 1970 e-body with 2 inch TTi's. The scattershield is more of a concern with the pan in my case. The pan has to be installed and the engine put in sans bellhousing and clutch to clear the k-member.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Mopar Guy]
#1363560
01/03/13 10:40 PM
01/03/13 10:40 PM
Posts: 749 NY
Beep Beep
NY
Thanks everyone for the great feedback. I was looking at the Milodon 7 quart deep pan, but I am going to spend the extra money and get the Road Race Pan. I am glad it will work with TTI headers. jbc426, that is one sweet Cuda!
[Re: Beep Beep]
#1363563
01/04/13 04:49 AM
01/04/13 04:49 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
[Re: autoxcuda]
#1363564
01/04/13 05:32 AM
01/04/13 05:32 AM
jbc426
West Coast, USA
Wow, mine doesn't even come close to hitting like that. Interesting.
[Re: jbc426]
#1363567
01/04/13 06:35 AM
01/04/13 06:35 AM
autoxcuda
So Cal
I think there is a lot of variability in aftermarket suspension pieces.
Also nubs on the LCA can act as bump stops to the turning radius. Sometimes the LCA gets worn at the stop and might increase the amount of angled.
I bet that is an aftermarket (new hemi mounts welded on) Hemi K-member in this car too.
Lot of potential for compounding errors.
[Re: Mopar Guy]
#1363569
01/04/13 09:36 AM
01/04/13 09:36 AM
jbc426
West Coast, USA
Thanks, It's fun to drive. I threw some 255/ 60 15's on the back, and it's like driving the car on a snow covered road while on dry pavement. The torque and street manners are incredible on the center carb, but once the outboards kick in, it's scary!
I have the stock idler & pitman arms on it, and love this pan because of the ground clearance. I did have to slot my windage tray to allow room for the pick-up too. I'm also running Milodon's new billet pump with the stock cast iron cover. It takes less power to turn, so it's eaisier on my bronze drive gear.
[Re: Keith Black®]
#1363573
01/05/13 06:48 PM
01/05/13 06:48 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
2
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Keith Black®]
#1363574
01/05/13 06:55 PM
01/05/13 06:55 PM
Keith Black®
QLD Australia
We also modified the pickup ...
