Adding 2nd rear caliper #1363320
01/02/13 08:32 PM
01/02/13 08:32 PM
new york usa
P
pattyboy 572 Offline OP
P
new york usa
Hi to all seasons greetings...wish to add a second rear caliper to my dana 60 ...currently have wilwood 4 piston dynalites...foot brake car,unable to hold...(wilwood dynalites in front as well)..looking for suggestion...products installation ease etc.... thanks.. pat 8 inch convert.4.30.. 10.5 w's
Re: Adding 2nd rear caliper [Re: pattyboy 572] #1363321
01/02/13 08:42 PM
01/02/13 08:42 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'm not seeing a kit for mopar housing ends, you'll likely have to make the bracket
http://www.wilwood.com/PDF/Flyers/fl58.pdf
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Adding 2nd rear caliper [Re: pattyboy 572] #1363322
01/02/13 08:52 PM
01/02/13 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would be better off with drum brakes to hold you
at the line... drum brakes cam the shoes around and
lock better when standing still... disc brakes work
better when rolling and use the heat
Re: Adding 2nd rear caliper [Re: MR_P_BODY] #1363323
01/02/13 09:09 PM
01/02/13 09:09 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My dad got a setup from strange. If I recall correctly he was very happy with it.
68 Barracuda Formula S 340
Re: Adding 2nd rear caliper [Re: Bad340fish] #1363324
01/02/13 09:24 PM
01/02/13 09:24 PM
Dyno1 Offline
Dyno1  Offline
My buddy has double rear M/W calipers on his 64 Savoy.
Re: Adding 2nd rear caliper [Re: pattyboy 572] #1363325
01/02/13 09:44 PM
01/02/13 09:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how much are you trying to stall it at?
Re: Adding 2nd rear caliper [Re: Quicktree] #1363326
01/02/13 11:33 PM
01/02/13 11:33 PM
new york usa
P
P
new york usa
5300 rpm
Re: Adding 2nd rear caliper [Re: pattyboy 572] #1363327
01/03/13 12:05 AM
01/03/13 12:05 AM
Q
Quicktree Offline
Quicktree  Offline
Q
5300 rpm
thats what I thought.thats never going to happen no matter what brake you use.if you want that much you better get a transbrake.
Re: Adding 2nd rear caliper [Re: Quicktree] #1363328
01/03/13 09:46 AM
01/03/13 09:46 AM
gregsdart Online content
gregsdart  Online Content
Using the biggest brakes ever made would probably still come up short. It is not the rpm so much as how the converter works too. My 6500 stall would probably flash to 6700 behind a 572, and only half the output torque at 5300. The same converter tightened up to stall at 5300 would obviously make max output torque at that rpm. Why do you want to stall so high?
On what brakes to use, adapting the absolute biggest, widest drums you can find is a start. The master cylinder needs to be as small as you can use with the system, for leverage. There are 7/8 bore master cylinders available, but the peddle travel might get very long, to the point of having to go bigger on the cylinder size.
The shoes will need some work as well to stand the extra load. Check with the roundyround crowd for the best brake shoes and parts. I don't know much about that but heard there is better stuff made for circle track racing. You may even be able to go as far as having a set of shoes custom lined for you. There was an article some years ago on setting up drum brakes for foot braking and hopefully someone with a great memory will chime in.
Re: Adding 2nd rear caliper [Re: pattyboy 572] #1363329
01/03/13 01:06 PM
01/03/13 01:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I use a 2nd caliper in the rear but as an E-brake but held my car at 5500 testing it.There is a topic on it"hydraulic E-Brake" about 9 months ago.
Re: Adding 2nd rear caliper [Re: Clanton] #1363330
01/03/13 01:11 PM
01/03/13 01:11 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Why can the brakes not hold to 5300? I work on a few turbo cars that can footbrake to over 5000 making 7-9 lbs of boost and not move an inch. All you have to do is get the right converter and a dual setup for the back and you can do what you are wanting to do no problem.
One day I will have something cool here.
Re: Adding 2nd rear caliper [Re: sdaurity] #1363331
01/03/13 01:28 PM
01/03/13 01:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
maybe if you had the right converter, but I see no gain in doing so na. you want the converter to flash not stall at max foot braking.
Re: Adding 2nd rear caliper [Re: Clanton] #1363332
01/04/13 02:57 PM
01/04/13 02:57 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
https://board.moparts.org/ubbthreads/show...rue#Post7133311
here is my topic on by building brackets for the dbl caliper.
Re: Adding 2nd rear caliper [Re: Bad340fish] #1363333
01/05/13 01:17 AM
01/05/13 01:17 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes I was able to just get the new bracket and another caliber from Strange. Between that and replacing a lot of -4 hose with tubing and -3 the brakes will hold the car rock solid on the line, better than when it had drum brakes.
Very pleased.
Bill
Re: Adding 2nd rear caliper [Re: 340Cuda] #1363334
01/05/13 01:57 AM
01/05/13 01:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Very pleased.
Bill
Question for you.... what size drum brakes to what
size disc brakes
Re: Adding 2nd rear caliper [Re: MR_P_BODY] #1363335
01/05/13 04:48 PM
01/05/13 04:48 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
old schoolers used a motorcycle disc rotor attached at the pinion . holds a ton..
you see it alot on monster trucks..fwiw..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
