Adding 2nd rear caliper
#1363320
01/02/13 08:32 PM
01/02/13 08:32 PM
Posts: 452 new york usa
pattyboy 572
new york usa
Hi to all seasons greetings...wish to add a second rear caliper to my dana 60 ...currently have wilwood 4 piston dynalites...foot brake car,unable to hold...(wilwood dynalites in front as well)..looking for suggestion...products installation ease etc.... thanks.. pat 8 inch convert.4.30.. 10.5 w's
Re: Adding 2nd rear caliper
[Re: pattyboy 572]
#1363322
01/02/13 08:52 PM
01/02/13 08:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You would be better off with drum brakes to hold you at the line... drum brakes cam the shoes around and lock better when standing still... disc brakes work better when rolling and use the heat ![](/ubbthreads/images/graemlins/wave.gif)
[Re: pattyboy 572]
#1363327
01/03/13 12:05 AM
01/03/13 12:05 AM
Quicktree
5300 rpm
thats what I thought.thats never going to happen no matter what brake you use.if you want that much you better get a transbrake.
[Re: Quicktree]
#1363328
01/03/13 09:46 AM
01/03/13 09:46 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Using the biggest brakes ever made would probably still come up short. It is not the rpm so much as how the converter works too. My 6500 stall would probably flash to 6700 behind a 572, and only half the output torque at 5300. The same converter tightened up to stall at 5300 would obviously make max output torque at that rpm. Why do you want to stall so high? On what brakes to use, adapting the absolute biggest, widest drums you can find is a start. The master cylinder needs to be as small as you can use with the system, for leverage. There are 7/8 bore master cylinders available, but the peddle travel might get very long, to the point of having to go bigger on the cylinder size. The shoes will need some work as well to stand the extra load. Check with the roundyround crowd for the best brake shoes and parts. I don't know much about that but heard there is better stuff made for circle track racing. You may even be able to go as far as having a set of shoes custom lined for you. There was an article some years ago on setting up drum brakes for foot braking and hopefully someone with a great memory will chime in.
[Re: sdaurity]
#1363331
01/03/13 01:28 PM
01/03/13 01:28 PM
Quicktree
Why can the brakes not hold to 5300? I work on a few turbo cars that can footbrake to over 5000 making 7-9 lbs of boost and not move an inch. All you have to do is get the right converter and a dual setup for the back and you can do what you are wanting to do no problem.
maybe if you had the right converter, but I see no gain in doing so na. you want the converter to flash not stall at max foot braking.
[Re: Bad340fish]
#1363333
01/05/13 01:17 AM
01/05/13 01:17 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
My dad got a setup from strange. If I recall correctly he was very happy with it.
Yes I was able to just get the new bracket and another caliber from Strange. Between that and replacing a lot of -4 hose with tubing and -3 the brakes will hold the car rock solid on the line, better than when it had drum brakes.
Very pleased.
Bill
[Re: 340Cuda]
#1363334
01/05/13 01:57 AM
01/05/13 01:57 AM
MR_P_BODY
Very pleased.
Bill
Question for you.... what size drum brakes to what size disc brakes ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1363335
01/05/13 04:48 PM
01/05/13 04:48 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
old schoolers used a motorcycle disc rotor attached at the pinion . holds a ton.. you see it alot on monster trucks..fwiw..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
