Painting Steelies with Tires Still Mounted #1362524
12/31/12 11:44 PM
12/31/12 11:44 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Howdy Moparts. I was just wondering if anyone has painted their steelies with their tires mounted? I've got some steel wool (3 - course), sand paper, rattle can primer and satin black paint, and some masking tape and cardboard. My steelies look a little faded and have a little surface rust on them. I'm starting to think I like the black steelies look instead of having my early 70's hubcaps.
Re: Painting Steelies with Tires Still Mounted [Re: MuuMuu101] #1362525
01/01/13 12:25 AM
01/01/13 12:25 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Spread a good coat of vaseline on the tire from the rim out past the area you think will get oversprayed. After painting it wipes off and washs away leaving no paint on the tire.
Re: Painting Steelies with Tires Still Mounted [Re: MuuMuu101] #1362526
01/01/13 01:08 AM
01/01/13 01:08 AM
I"m fixing to as soon as the weather warms up. going to glassbead em with a HF $24.99 blast gun/5lbs (or more)of HF beads $7.99 for 5 lb pkg then tape off the tires & spray em. Just not sure which rattle can to use but Rustoleum gets high marks when it's mentioned
Re: Painting Steelies with Tires Still Mounted [Re: stumpy] #1362527
01/01/13 04:06 AM
01/01/13 04:06 AM
SoCal
SoCal
That doesn't sound too bad at all. Thanks!
Re: Painting Steelies with Tires Still Mounted [Re: MuuMuu101] #1362528
01/01/13 09:18 AM
01/01/13 09:18 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
I have stuffed 3x7 recipe index cards in around the bead and sprayed rattle can paint
Re: Painting Steelies with Tires Still Mounted [Re: 360904] #1362529
01/01/13 12:55 PM
01/01/13 12:55 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Get some aluminum 6" wide flashing from the hardware store and form a ring around the outer edge of the rim (like a wall). Spray the rim after prep and the overspray should be kept off the tire.
Ron
Re: Painting Steelies with Tires Still Mounted [Re: MuuMuu101] #1362530
01/01/13 01:09 PM
01/01/13 01:09 PM
Tennessee
meep_meep Offline
meep_meep  Offline
Tennessee
I've always used a deck of playing cards stuck in around the tire bead...
Re: Painting Steelies with Tires Still Mounted [Re: meep_meep] #1362531
01/01/13 01:24 PM
01/01/13 01:24 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I have a cheap ($40 on sale) Harbor Freight tire changer. I break the bead on the front side and stuff rags between the tire and wheel, much easier than masking it off.
Before I had the tire changer, I broke the bead with a bumper jack or by driving on it with another vehicle.
Re: Painting Steelies with Tires Still Mounted [Re: MuuMuu101] #1362532
01/01/13 02:53 PM
01/01/13 02:53 PM
Alberta
rustbuckett68 Offline
Alberta
After the paint job, a couple coats of clear makes a huge difference in longevity.
Re: Painting Steelies with Tires Still Mounted [Re: meep_meep] #1362533
01/01/13 03:49 PM
01/01/13 03:49 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
That's how I do it only I let the air out of the tire so the cards will go in further
Run a row of tape close to the rim on the cards & massk out with paper
I've also broke them down on one side with a bumper jack masked them & painted
Re: Painting Steelies with Tires Still Mounted [Re: BulletBob] #1362534
01/02/13 02:33 AM
01/02/13 02:33 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Did mine with masking tape a couple of years ago, worked out OK...
The masking was A lot of work...
Re: Painting Steelies with Tires Still Mounted [Re: RapidRobert] #1362535
01/02/13 08:07 AM
01/02/13 08:07 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
They reformulated a lot of the spray bombs again, sometime over a year ago. The Rustoleum paint will soften, wrinkle up and lift when several coats are sprayed over itself. I threw out several cans after a few parts were messed up.
I've quit using Rustoleum and started using Dupli-Color, which I've been getting from O'Rielly's Auto. The paint quality of their entire line is very good, especially the engine paints, which I use whenever I want a color available in it. I'm very impressed with the durability, laydown and even the spray nozzels on their product line.
Re: Painting Steelies with Tires Still Mounted [Re: jbc426] #1362536
01/02/13 08:57 AM
01/02/13 08:57 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I like using Gloss Back Engine enamel simply because it seems pretty hardy. I also see guys using fusion paint.
I'll be in this boat, but it would be so nice to have them powder coated... I may have to get mine taken off, powder coat, and then go get the new tires put on.....
Re: Painting Steelies with Tires Still Mounted [Re: jbc426] #1362537
01/02/13 12:11 PM
01/02/13 12:11 PM
I will take your advise & get some Dupli color. Thank you! After glassbeading (steelies) should I spray some primer and or sand first or just clean with wax/grease remover then several light coats of Duplicolor? And you soap/water clean if needed then wax/grease remover before initial sanding but does that technique/order still apply when glassbeading instead of hand sanding
Re: Painting Steelies with Tires Still Mounted [Re: 360904] #1362538
01/02/13 08:39 PM
01/02/13 08:39 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
this takes all of 30 seconds per wheel and gives perfect results
Re: Painting Steelies with Tires Still Mounted [Re: Pool Fixer] #1362539
01/02/13 08:50 PM
01/02/13 08:50 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes we've all done it. I usually use duplicolor engine enamel, it leaves a decent finish. But if you really want to do a nice job, there's no substitute for taking off the tire to have the rim blasted and powder coated.
Re: Painting Steelies with Tires Still Mounted [Re: MuuMuu101] #1362540
01/02/13 10:28 PM
01/02/13 10:28 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I do the same sort of thing with tire shine
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
