Re: Painting Steelies with Tires Still Mounted
[Re: stumpy]
#1362527
01/01/13 04:06 AM
01/01/13 04:06 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Spread a good coat of vaseline on the tire from the rim out past the area you think will get oversprayed. After painting it wipes off and washs away leaving no paint on the tire.
That doesn't sound too bad at all. Thanks!
[Re: meep_meep]
#1362533
01/01/13 03:49 PM
01/01/13 03:49 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
I've always used a deck of playing cards stuck in around the tire bead...
That's how I do it only I let the air out of the tire so the cards will go in further Run a row of tape close to the rim on the cards & massk out with paper
I've also broke them down on one side with a bumper jack masked them & painted
[Re: RapidRobert]
#1362535
01/02/13 08:07 AM
01/02/13 08:07 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I was just wondering if anyone has painted their steelies with their tires mounted?
I"m fixing to as soon as the weather warms up. going to glassbead em with a HF $24.99 blast gun/5lbs (or more)of HF beads $7.99 for 5 lb pkg then tape off the tires & spray em. Just not sure which rattle can to use but Rustoleum gets high marks when it's mentioned
They reformulated a lot of the spray bombs again, sometime over a year ago. The Rustoleum paint will soften, wrinkle up and lift when several coats are sprayed over itself. I threw out several cans after a few parts were messed up.
I've quit using Rustoleum and started using Dupli-Color, which I've been getting from O'Rielly's Auto. The paint quality of their entire line is very good, especially the engine paints, which I use whenever I want a color available in it. I'm very impressed with the durability, laydown and even the spray nozzels on their product line.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 360904]
#1362538
01/02/13 08:39 PM
01/02/13 08:39 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I have stuffed 3x7 recipe index cards in around the bead and sprayed rattle can paint
this takes all of 30 seconds per wheel and gives perfect results
