Valve stem height in 906 #1362495
12/31/12 09:34 PM
12/31/12 09:34 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
What is the valve stem height supposed to be for 906 heads? The FSM says to use tool #XXX to measure it but doesn't say what the measurement is or the tolerances are.
Re: Valve stem height in 906 [Re: VITC_GTX] #1362496
01/01/13 12:14 PM
01/01/13 12:14 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
340 1.907 - 1.937
400 2.123 - 2.153
383 - 440 2.095 - 2.125 (906) and other numbers
426 Hemi 2.048 - 2.078
.030 is the typical range for stem heights, you must keep in mind also how much heads have been milled ? and if your using adjustable rockers or not.
MLR426
Re: Valve stem height in 906 [Re: MLR426] #1362497
01/01/13 03:39 PM
01/01/13 03:39 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the numbers
Re: Valve stem height in 906 [Re: VITC_GTX] #1362498
01/01/13 10:41 PM
01/01/13 10:41 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Your welcome, your bill is in the mail
Installed spring height correction with shims may also be needed for correcting spring pressure. 1.860 is typical installed height with standard valve lengths.
MLR426
