Spring Pressures #1362400
12/31/12 06:32 PM
12/31/12 06:32 PM
western PA
Sb Valiant Offline OP
western PA
What kind of spring pressures are you running with your 500 to 575 lift Flat Tappet cam?
Re: Spring Pressures [Re: Sb Valiant] #1362401
12/31/12 06:43 PM
12/31/12 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should state what type of cam... hyd, flat tappet
or a roller... ramp rates would sure help also
Re: Spring Pressures [Re: MR_P_BODY] #1362402
12/31/12 06:46 PM
12/31/12 06:46 PM
western PA
western PA
Sorry, Flat Tappet cam.
Re: Spring Pressures [Re: Sb Valiant] #1362403
01/01/13 12:13 AM
01/01/13 12:13 AM
As Mike has said, the lobes will dictate the valve spring pressure needed, It is best to call the cam company with your grind number and ask them I have used from 110 lbs on the seats with 325 Lbs. open pressures on small lift cams like your asking about and I have used 175 lbs. on the seat with 425 lbs. opened, that was on a race cam for a 418 C.I. W2 headed pump gas small block street and srip with NASCAR lobes, we had to break the cam in with the inner springs removed, 130 lbs. on the seats and 300 lbs. opened for 30 minutes efore adding the inner springs That cam was nitrided also Find out who made the cam and call them
Re: Spring Pressures [Re: Cab_Burge] #1362404
01/01/13 07:01 AM
01/01/13 07:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i used to run a 535 lift flat tappet cam & used Comp Cams 930 springs. they were 153lbs on the seat. they worked well for that cam for me, never any sign of valve bounce on the locks.
Re: Spring Pressures [Re: rebel] #1362405
01/01/13 03:18 PM
01/01/13 03:18 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
130 seat and 330 open. Would like to try a little more.
Yeah, it's got a smallblock.
