Help with PCB delaminating #1362277
12/31/12 03:21 PM
12/31/12 03:21 PM
Northeast
V
VincentVega Offline OP
V
Northeast
I noticed that my instrument cluster PCB (printed circuit board) is delaminating in a few areas. There's nothing wrong with the copper traces or anything like that. Any idea what I can use to glue it back together? Would prefer something flexible
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Help with PCB delaminating [Re: VincentVega] #1362278
01/06/13 01:16 AM
01/06/13 01:16 AM
Northeast
V
V
Northeast
Anyone know what these things are made of? After doing some research, I think it's Kapton
Re: Help with PCB delaminating [Re: VincentVega] #1362279
01/06/13 02:26 AM
01/06/13 02:26 AM
Cab_Burge Online work
Cab_Burge  Online Work
How about super glue or five minute epoxy? Do you have a senitive Volt Ohm meter ? If so spread some on the edge where there is no circuits and let it dry and measure across it to see if it conducts or not I had to make printed circuit boards for a small solid state amplifyer in a electronic class years ago, I'll be dang if I can remember what they said those boards where made out of We used some kind marker that resisted acid to make the circuits and then soaked them in acid for a few minutes to remove the unwanted part of the rest of the board Solder the components in and if it worked, mine did, you got a passing gradde for the project
Re: Help with PCB delaminating [Re: Cab_Burge] #1362280
01/06/13 12:18 PM
01/06/13 12:18 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have used clear finger nail polish before.
Re: Help with PCB delaminating [Re: slantzilla] #1362281
01/06/13 12:23 PM
01/06/13 12:23 PM
Northeast
V
V
Northeast
it's definitely going to be some kind of glue, but regular epoxy cures very hard and I would like the repair to be just as flexible as the rest of it.
I emailed one of my bosses who runs several electronics companies and asked if he can send me anything they use in pcb prototyping. if he does, or if I come up with any valuable information, I'll post it here.
@slantzilla, that's a neat idea... do you recall if it was flexible? my worse repair area is going to be about 2 square inches
I'm going to try to do some more research on Kapton cement or epoxy.. found some stuff so far but only by big industry suppliers
Re: Help with PCB delaminating [Re: VincentVega] #1362282
01/06/13 01:07 PM
01/06/13 01:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I used to repair and rebuild PCB's back in my sailor days and I'll be darned if I can remember other than it was a two part clear epoxy, got out in 93 so it's been a few years.
Don't be the exception.
Re: Help with PCB delaminating [Re: Supercuda] #1362283
01/06/13 01:25 PM
01/06/13 01:25 PM
Northeast
V
V
Northeast
thanks!
Re: Help with PCB delaminating [Re: VincentVega] #1362284
01/06/13 04:50 PM
01/06/13 04:50 PM
Most five minute epoxys remain flexable, I use them on carbs to reseal the lead insert plugs. It is fuel restistance
