leaveing off a t-stop #1362009
12/30/12 11:44 PM
12/30/12 11:44 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
i've currently been useing a convertor that that is 5500 stall and works well. now i'm going to a throttle stop that will be activated 2 tenths off the line, would you still stay with that convertor or would it make you consider a different stall?
Re: leaveing off a t-stop [Re: Deepockets] #1362010
12/31/12 12:15 AM
12/31/12 12:15 AM
Lehigh Acres, Florida
rickstershemi Offline
IMO....no reason to change....my s-gas vette had a 6k stall and always left against the converter and stop came on at .150
Rickster
Re: leaveing off a t-stop [Re: rickstershemi] #1362011
12/31/12 07:33 AM
12/31/12 07:33 AM
Arizona
Chris'sBarracuda Offline
Arizona
Glide or TF??
When you come off the stop in high gear you will see your stall speed..
Some guys have been known to use .000 off the brake to the stop..
Chris..
Re: leaveing off a t-stop [Re: Chris'sBarracuda] #1362012
12/31/12 11:47 AM
12/31/12 11:47 AM
glendora, ca.
glendora, ca.
chris, it's a glide. why would or would'nt you leave right off the stop or ad delay. also, i was at 4000 on my 2 step before. should that stay the same or not?
Re: leaveing off a t-stop [Re: Deepockets] #1362013
01/01/13 08:07 PM
01/01/13 08:07 PM
Arizona
Arizona
I use anywhere between 3800-4600 off the line and am on the stop early.
The converter choice is a tough deal. 5000 seems low to me.,. I'm @ 6200-6400..
Chris..
