Re: 408 stroker do's/donts
[Re: 67valiant]
#1361873
12/30/12 11:09 PM
12/30/12 11:09 PM
Posts: 9,893 Weddington, N.C.
Streetwize
Weddington, N.C.
Plenty of great info already in the tech archive/best of Moparts. Huge detailed database. Set enough $$$ aside for good heads that will flow at least 270 by .550 lift, the more the better, otherwise the motor won't want to pull in the upper ranges. Don't overcam or run too loose a converter unless your combo is very light. Strokers love single plane intakes and big cfm carbs when you build them at or above the 10.75:1 range. Lots more will chime in , just want to get the thread rolling ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Crizila]
#1361879
12/31/12 12:03 PM
12/31/12 12:03 PM
A high quality oil pan is a must--Charlies comes to mind--the deeper the better as the 408's can and do act like a blender with crank case oil--run as little oil as possible ( I just don't think you need 7 qts) run six or less. Some can hit a standard dipstick, be sure and check that during build. Vent valve covers well and keep breathers near the front for sure. A good one feels like a big block, you are going to have some fun! I agree with Wise, they likey some good heads--do not skimp on rocker arms--get some good ones. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 67valiant]
#1361881
12/31/12 02:21 PM
12/31/12 02:21 PM
Posts: 2,141 junction city oregon
viperblue72
I ran a 10.5 to 1 408 in 3150lb duster. With mild ported eddies and 248/577 roller 3k stall and 4.10s ran 11.20s@118. Put on indybrocks, and ran 2 passes only went 11.09@122 with bad 1.65 60ft. No oiling mods, but 7qt pan. Ran it to 6800 rpm all the time. Also carb I ran was proform 950. Intake was an m1 then a victor. You will be surprises how well it will probably run.
[Re: viperblue72]
#1361883
12/31/12 03:26 PM
12/31/12 03:26 PM
dartman366
Mt. Vernon, Ohio
Fun motor, mine is 13.0 to 1 comp and lg port Commando's .688int-.672ex roller set-up and Indy int w/1050 dommy,,5900stall,904, 4.56 dana,,,I twist it to 6800 at each shift and run's 10.00's to 9.90 all day long. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Streetwize]
#1361886
12/31/12 05:55 PM
12/31/12 05:55 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Justin,
What converter are you running with your combo?
Its a Edge Racing 9.5" that flashes 5000. I've been 1.38 60' but usually goes 1.40-1 on radials.
[Re: dodgeboy11]
#1361890
01/01/13 09:08 AM
01/01/13 09:08 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I wouldn't take an eagle crank for a mopar period. Especially not a cast crank.
Friend with a Dakota broke one inside a few miles right at the number 7/8 journal. Eagle told him his transmission broke it shifting to hard!
I kid you not... He is still pissed off, they refused to make good on it.
