1970 Belevedere wheel stud issues please help #1361612
12/30/12 03:58 PM
12/30/12 03:58 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
In changing the left handed wheel studs on my 70 bell I find I can't get a stud that will pull up correctly on the front. I have the 10" drums. The part numbers I find call for a 1/2x20 .625 or 5/8 spline. Dorman #610-039.1 is the part number I found but the spline area is to small. I sorted through the parts ben and found a 1/2x20 .640 spline, it was close, I thought it was going to work but it spun when I tightened the lug nut with ease. Can anyone help me out with finding the correct right hand tread parts?
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361613
12/30/12 04:22 PM
12/30/12 04:22 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Orielys has a book about 1" thick full of right hand studs.
Take your info and browse till you find what you are looking for.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 1970 Belevedere wheel stud issues please help [Re: BB65Barracuda] #1361614
12/30/12 05:42 PM
12/30/12 05:42 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Thanks, not sure what I'm looking for. That's where the problem is.
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361615
12/30/12 06:56 PM
12/30/12 06:56 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Do you think its possible that during production they may of run low on the correct .625" diam it calls for with 10" drums and substituted a .650" diam that they call for on 11" drums to keep production rolling?
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361616
12/30/12 07:05 PM
12/30/12 07:05 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
When you pulled the old studs out, did you cut off the swedge ? If not it might have enlarged the holes as you pressed them out.
Re: 1970 Belevedere wheel stud issues please help [Re: OzHemi] #1361617
12/30/12 07:20 PM
12/30/12 07:20 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
What was protruding out from the hub was substantially smaller then the spline so there was nothing pressed back through that would enlarge the openings. I did front and rear the same and the rear works fine. I went up in size from .625"-.640" and still to small.
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361618
12/30/12 10:10 PM
12/30/12 10:10 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Outside is new and old rear, center is old front. No "swedge" of any sorts to cut/remove. Any other ideas?
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361619
12/30/12 10:41 PM
12/30/12 10:41 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
In the photo, it looks like the splines are not in the same location; maybe insufficient engagement?
Is it possible that the LH studs have been replaced before and the splines are worn/enlarged?
I'd spend some time with the wheel stud catalog at the local NAPA.
Re: 1970 Belevedere wheel stud issues please help [Re: topside] #1361620
12/31/12 05:03 AM
12/31/12 05:03 AM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Thanks, the one in the middle is the problem stud. The spline runs the length of the shank. The new one was a good fit in the rear.
Re: 1970 Belevedere wheel stud issues please help [Re: BB65Barracuda] #1361621
12/31/12 08:25 AM
12/31/12 08:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Find a right hand drum.There should be plenty out there.A while ago I had some from the Charger my kid scraped.Couldnt get 10 bucks each for them.They were like new and had never been cut.Rocky
Chrysler Firepower
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361622
12/31/12 11:49 AM
12/31/12 11:49 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
From the looks of it the center stud in the pic was swedged in.
It's fatter at the top just below the threaded area.
You can see where the splines in the drum were cut into it when it was forced out.
The holes in the drum are now larger than what the factory studs require. They're never gonna fit tight using the stock studs.
It's gonna take a stud with a larger splined area.
You need to go to a real auto parts store (NAPA, etc) where someone that actually knows about cars (and parts) can help you find a stud that will fit.
Re: 1970 Belevedere wheel stud issues please help [Re: SNK-EYZ] #1361623
12/31/12 12:24 PM
12/31/12 12:24 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
I found this, what's the difference between a motor wheel drum and bud drum?
DORMAN Part # 610039 More Info {#6100391, 98147, 981471} Serrated Stud; Thread; 1/2-20; Knurl Dia.: .625"; Length: 1-5/8"; Shoulder Length: 23/32"
Front Right; 1-5/8" Length; w/10" Front Drum; Motor Wheel
$1.41
DORMAN Part # 610122 More Info {#2460614, 6101221} Serrated Stud; Thread; 1/2-20; Knurl Dia.: .650"; Length: 1-9/16"; Shoulder Length: 5/8"
Front Right; 1-9/16" Length; w/10" Front Drum; Budd
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361624
12/31/12 04:09 PM
12/31/12 04:09 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I'd say try the Dorman 610-122 in the hub/drum.
If I'm reading it right it's .025 larger in diameter in the knurld area.
Anything short of you measuring the hole diameter is just a guess.
http://www.dormanproducts.com/p-29953-610-122.aspx
Re: 1970 Belevedere wheel stud issues please help [Re: SNK-EYZ] #1361625
12/31/12 05:38 PM
12/31/12 05:38 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Take a hammer and dolly and flatten the holes again, Take a ball peen and go around the outside of the hole, they will press in again. The left stud you have pictured is the rear axle, the middle one that is bent was swedged in the front hub, thats why you had to beat the crap out of it. Back in the day they had a little cutter that would take off that ridge flush with the hub, and then it would come out. I guess that practice went away with the left hand threads, although some vehicles still use em.
Re: 1970 Belevedere wheel stud issues please help [Re: cageman] #1361626
01/08/13 11:46 PM
01/08/13 11:46 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
No no no, NO WAY. After ordering the .650" wheel studs I found my issue before pulling the first one into place. BUDD hubs and drums. I got this now.
Re: 1970 Belevedere wheel stud issues please help [Re: SNK-EYZ] #1361627
01/09/13 12:09 AM
01/09/13 12:09 AM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Clearly marked BUDD. Who new? I never heard of this before.
Re: 1970 Belevedere wheel stud issues please help [Re: MrRico] #1361628
01/09/13 12:48 AM
01/09/13 12:48 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
At least you've got it figured out.
