48º r block questions help
#1361136
12/29/12 10:02 PM
12/29/12 10:02 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Re: 48º r block questions help
[Re: RAY1969CARS]
#1361137
12/29/12 10:08 PM
12/29/12 10:08 PM
Posts: 6,145 Melbourne , Australia
LA360
You won't be able to use the lifters as the tie bars are different. Machining costs will be the same as your factory block.
You will need to check out what size tunnel it has as some blocks had the 1.998" journal tunnel. Otherwise they will run a 50mm or 60mm camshaft.
The pushrod holes will need to be machined on your W5 heads.
In the long run, it will be worth the extra effort
Alan Jones
[Re: RAY1969CARS]
#1361141
12/29/12 11:10 PM
12/29/12 11:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
cam is 1.998 journal if thats stock ???? thev guy told me is uses stock cam bearing. what lifters will i need ?????? what will a cam cost me ???
Has this block been run yet... if its new you need to get it line honed ... the new blocks cant be run without honing
[Re: MR_P_BODY]
#1361145
12/30/12 03:36 AM
12/30/12 03:36 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
yes the block is new
[Re: vc360]
#1361148
12/30/12 09:56 AM
12/30/12 09:56 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
The cam bearing bores for the babbit bearings are all the same , not stepped like a stock block........on the 48 degree blocks. P 4876372 59 degree R blocks should have stepped bearings like a production block and use standard bearings. That being said , I understand that " standard " doesn't necessarily apply to R-3 blocks and there are a lot of variations that you need to look for. If it requires babbit bearings , the oil filter boss and rear main cap should be machined. If you notice the drill mis alignment at the bottom of the hole for the oil filter , be VERY careful if you decide to clean it up with a die grinder.......or be prepared to use a remote filter and do some drilling , tapping and plugging at the filter boss. DAHIK. And if you plan on a wet sump , give some thought to oil drainback and be prepared to put the ideas you come up with to work.
[Re: tubtar]
#1361151
12/30/12 12:00 PM
12/30/12 12:00 PM
MR_P_BODY
The fixture
I put a steel sleeve in that fixture so I could use a 1/16" bit
[Re: MR_P_BODY]
#1361152
12/30/12 01:50 PM
12/30/12 01:50 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
That is a nice fixture. But, not all lifters and cam base circle need the oil hole in the same place. I would not want the oil feed hole to be any larger than .028". These blocks are notorious for over oiling the top end. I have replaced lifters with another brand and had to cut a gateway from where the oil feed was and the EDM hole on the lifter. A lot of intake lifters have the EDM hole offset.
With my past experiences on these engines I would not run a comp lifter period. Morrel and Crower both prooved to be excellent choices.
Leon
[Re: Leon441]
#1361153
12/30/12 03:12 PM
12/30/12 03:12 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Leon
I agree we went to ISKy this build,
[Re: tubtar]
#1361154
12/30/12 07:54 PM
12/30/12 07:54 PM
Posts: 426 Cairns Queensland Australia. T...
vc360
My 48 degree "R" block used std la cam bearings and sounds like the OP does too?
[Re: DakFink]
#1361155
12/30/12 10:06 PM
12/30/12 10:06 PM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
Have you got the Part Number for the block?
This seems to be pretty important to know...
