Tubes -- to Tube or not to Tube? #1361126
12/29/12 09:54 PM
12/29/12 09:54 PM
New Hampshire
63Hemi Offline OP
63Hemi  Offline OP
New Hampshire
Hi Folkes:
I'm building a Front Engine Dragster. Strickly for nostalgia
bracket racing. 514 Hemi powered ~880hp on alcohol.
I have double beadlocks for the car and I need to make a decision on
running tube or tubeless.
Is there a safety issue involved here or just a case of the tires
possibly leaking down overnight?
Tom
Re: Tubes -- to Tube or not to Tube? [Re: 63Hemi] #1361127
12/29/12 10:03 PM
12/29/12 10:03 PM
ky
68roadrunner Offline
ky
i dont know anybody in the rear engine dragsters that run tubes. i know some with that horsepower that dont even screw the wheel, much less have bead locks.
my wheels are screwed on mine with 750hp, no tubes, and they dont leak air very fast. brand of tire makes a difference on how they hold air.
Re: Tubes -- to Tube or not to Tube? [Re: 63Hemi] #1361128
12/29/12 10:14 PM
12/29/12 10:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its gonna make a difference if you need the extra
stiffness in the side walls.. on my brothers altered
we ran stiff sidewalls
Re: Tubes -- to Tube or not to Tube? [Re: MR_P_BODY] #1361129
12/29/12 10:31 PM
12/29/12 10:31 PM
New Hampshire
63Hemi Offline OP
63Hemi  Offline OP
New Hampshire
Hi Mike:
The tires are Hoosier 33/17 16 and are stiff wall.
As long as there isn't a safety issue, I'll go tubeless.
Tom
Re: Tubes -- to Tube or not to Tube? [Re: 63Hemi] #1361130
12/29/12 11:25 PM
12/29/12 11:25 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Hi Mike:
Tom
I ran my altered with 1490's tubeless.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Tubes -- to Tube or not to Tube? [Re: 63Hemi] #1361131
12/30/12 12:40 PM
12/30/12 12:40 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
All Hoosier's tires are reccomended to be run tubless.
If you like drag racing, support your local track.
Re: Tubes -- to Tube or not to Tube? [Re: CHAPPER] #1361132
01/01/13 01:37 AM
01/01/13 01:37 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
ditch the tubes, pour liquid dish detergent in the slick take a towel and wipe down the entire inside of the slick (load it up good), let it dry then repeat. this will help a lot with air loss it seals the pores in the slicks. yea i thought i was being yanked the first time someone told me to do it but it works.
Re: Tubes -- to Tube or not to Tube? [Re: jamesc] #1361133
01/01/13 03:35 AM
01/01/13 03:35 AM
I bought a set of M/T ET Streets, 12.50x30x15,that had 12 runs on them off of a heads up car that ran mid 8 in the 1/4, the sidewalls would not hold air tubeless until I soaked them inside like said above It works very well, I got another 120 runs out of them tubeless
Re: Tubes -- to Tube or not to Tube? [Re: jamesc] #1361134
01/01/13 10:04 AM
01/01/13 10:04 AM
New Hampshire
63Hemi Offline OP
63Hemi  Offline OP
New Hampshire
OK - Tubes are ditched(I didn't really want to fight with them
anyway) I will probably use Murphy's Oil Soap since Hoosier
recommends it for tube insertion. I'm guessing that it will stay
pliable and won't break down the rubber. I all ears if there is
something wrong with my logic.
Re: Tubes -- to Tube or not to Tube? [Re: 63Hemi] #1361135
01/01/13 10:33 AM
01/01/13 10:33 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
That is the question.......
It is "nobler" to runith' untubed.....
