Tubes -- to Tube or not to Tube?
#1361126
12/29/12 09:54 PM
12/29/12 09:54 PM
Posts: 234 New Hampshire
63Hemi
New Hampshire
Hi Folkes: I'm building a Front Engine Dragster. Strickly for nostalgia bracket racing. 514 Hemi powered ~880hp on alcohol. I have double beadlocks for the car and I need to make a decision on running tube or tubeless. Is there a safety issue involved here or just a case of the tires possibly leaking down overnight? Thanks Tom
Re: Tubes -- to Tube or not to Tube?
[Re: 63Hemi]
#1361128
12/29/12 10:14 PM
12/29/12 10:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its gonna make a difference if you need the extra stiffness in the side walls.. on my brothers altered we ran stiff sidewalls
[Re: 63Hemi]
#1361131
12/30/12 12:40 PM
12/30/12 12:40 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
All Hoosier's tires are reccomended to be run tubless.
If you like drag racing, support your local track.
[Re: jamesc]
#1361133
01/01/13 03:35 AM
01/01/13 03:35 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
ditch the tubes, pour liquid dish detergent in the slick take a towel and wipe down the entire inside of the slick (load it up good), let it dry then repeat. this will help a lot with air loss it seals the pores in the slicks. yea i thought i was being yanked the first time someone told me to do it but it works.
I bought a set of M/T ET Streets, 12.50x30x15,that had 12 runs on them off of a heads up car that ran mid 8 in the 1/4, the sidewalls would not hold air tubeless until I soaked them inside like said above It works very well, I got another 120 runs out of them tubeless
[Re: jamesc]
#1361134
01/01/13 10:04 AM
01/01/13 10:04 AM
63Hemi
New Hampshire
OK - Tubes are ditched(I didn't really want to fight with them anyway) I will probably use Murphy's Oil Soap since Hoosier recommends it for tube insertion. I'm guessing that it will stay pliable and won't break down the rubber. I all ears if there is something wrong with my logic.
