HEMI BLOCK CASTING DATES????
#136058
10/13/08 09:51 PM
10/13/08 09:51 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Were any blocks produced for the 1967 model year?Or did they use '66 blocks untill the '68's were poured?
Re: HEMI BLOCK CASTING DATES????
[Re: hemi-itis]
#136059
10/13/08 10:21 PM
10/13/08 10:21 PM
Posts: 2,483 Minneapolis, MN
hemi70se
Minneapolis, MN
No 1967 HEMI blocks were cast. I've been keeping a scorecard on casting dates for 20 years now. The latest 66 block is 10-31-66 and then they were not cast again until 4-15-68. So unless you own one of the very last 68 hemi cars it's going to have a 66 block in it. All 67 Hemi cars would have a 66 cast block. As an interesting sidenote they only cast blocks 4 times in the whole year of 1969. 5-18-69 5-26-69 7-28-69 8-18-69
[Re: hemi70se]
#136060
10/14/08 09:10 AM
10/14/08 09:10 AM
hemi-itis
So when did the 67 models go into production?Would a 10/10/66 block still be in a 66 or 67??
[Re: hemi-itis]
#136061
10/14/08 09:56 AM
10/14/08 09:56 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
10/10/66 is 2 months into the 67 MODEL YEAR , you would NEVER see that casting date in a 66 model year built car ORIGINALLY .
[Re: ogopogo]
#136065
10/30/08 12:33 AM
10/30/08 12:33 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Not all of them did, some 67 cars had leftover 65 blocks. The 67 Hemi Belvedere I had, SPD 11/22/1966, had an 8/17/1965 casting date block wich was assembled 11/16/1966. Although I've never seen one, it's also possible that a 68 car recieved a 65 dated block, there was no order to when 65 or 66's were used, they just pulled and built them at random.
As mentioned, no 67 blocks were cast.
[Re: ScottSmith_Harms]
#136070
10/31/08 11:29 AM
10/31/08 11:29 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
You guys are right. I've got a block that's probably from an early 68 car that has the #'s on the pad MN42633601 overstamped w/ 12-16-67, but the casting date is 10-3-66. The VIN looks like 201381A8. Will post it in the lost & found forum later.
#136071
10/31/08 07:59 PM
10/31/08 07:59 PM
Posts: 4,698 North Central USA (MN-WI area)
MuscleMopars
Anything date cast in 1965 or 1966, then depending on the build date of the car, 68 castings, which began around March 15 of 1968 as mentioned above in another post.
No, what I mean is in the year of 1968 what were the dates Chrysler cast the Hemi blocks?
Thanks, Eric email eric@musclemopars.com 715-426-HEMI (Shop) 612-669-CARS (Cell and Texts)Go to my Moparts "Profile" to see my web site
[Re: hemi70se]
#136074
11/01/08 11:30 PM
11/01/08 11:30 PM
MuscleMopars
Hmmm...what's this???
[Re: 6PakBee]
#136076
11/02/08 11:19 AM
11/02/08 11:19 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
A service block has nothing stamped there. Don't know about short blocks that had already been partially assembled.
Yes, service short block or a complete service engines would have had assembly information stamped into them somewhere (location varied with the year), obviously a bare block would not.
