BIG block water pump disassembly? #1360312
12/28/12 09:23 PM
12/28/12 09:23 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I want to rebuild my original big block water pump. Does anyone know how to take it apart? Thanks
Re: BIG block water pump disassembly? [Re: sbcjd] #1360313
12/28/12 11:11 PM
12/28/12 11:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'm a cheapskate and can't recall ever attempting such a thing. If you do get it apart, I would wonder where you would obtain the bearings-seals etc.
Re: BIG block water pump disassembly? [Re: buildanother] #1360314
12/28/12 11:12 PM
12/28/12 11:12 PM
4 bolts to take out/put new one in.
Are you doing a concours restoration?
Re: BIG block water pump disassembly? [Re: sbcjd] #1360315
12/28/12 11:13 PM
12/28/12 11:13 PM
Never have so I'm just thinking out loud. I think pressing the shaft out would be the easy part & more difficult would be finding/adapting a puller to pull the vanes off of the shaft (which you'd want to do first) without damaging the vanes
Re: BIG block water pump disassembly? [Re: sbcjd] #1360316
12/28/12 11:25 PM
12/28/12 11:25 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
http://www.ebay.com/itm/1954-55-56-331-c...=item53f06641fc
if a kit for yours is anything like this one, a new (non-rebuilt) part may be the better option.
http://www.ebay.com/itm/Chrysler-Mopar-b...bf1&vxp=mtr
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: BIG block water pump disassembly? [Re: hp383] #1360317
12/29/12 12:16 AM
12/29/12 12:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You have to be both a cheapskate AND a glutton for punishment to try this one - particularly since the net savings would be about $5 by the time you were done !!
Re: BIG block water pump disassembly? [Re: Stanton] #1360318
12/29/12 01:21 AM
12/29/12 01:21 AM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Thank you all for your input. Sounds like a no go. Can anyone recommend a shop that will rebuild my pump?
Re: BIG block water pump disassembly? [Re: sbcjd] #1360319
12/29/12 01:52 AM
12/29/12 01:52 AM
AndyF Offline
AndyF  Offline
I don't think a water pump can be rebuilt. I tried it once and didn't have any success. The shaft busted the housing when I tried to press it out.
Re: BIG block water pump disassembly? [Re: sbcjd] #1360320
12/29/12 04:40 AM
12/29/12 04:40 AM
Contact your local auto parts store, NAPA would be your best bet probally, and ask them if they can have yours rebuilt instead of just exchanging it I know there are, at least there use to be, commercial large volume rebuilders that would do that for a few dollars more than the standard over the counter rebuilt pumps, they where charging the extra for tracking that core internally and returning it back to that dealer
Re: BIG block water pump disassembly? [Re: Cab_Burge] #1360321
12/29/12 05:30 AM
12/29/12 05:30 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I know of a guy that comes out to Spring Fling and has original core rebuilt through a local auto parts store. I think he sells on Ebay too.
If you find a place that will rebuild your core, engrave your name or something on it and show the person receiving the part.
Re: BIG block water pump disassembly? [Re: autoxcuda] #1360322
12/29/12 10:32 AM
12/29/12 10:32 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Dont we have a "Worst of posts" around here for postings like this??
I am truckless..
Re: BIG block water pump disassembly? [Re: 340SHORTY] #1360323
12/29/12 11:08 AM
12/29/12 11:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
No sh!t !! It'll probably still be going 3 weeks from now !
Re: BIG block water pump disassembly? [Re: sbcjd] #1360324
12/29/12 11:25 AM
12/29/12 11:25 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
If you read the whole ebay listing, he indicated that his rebuilder will install the pump kit.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: BIG block water pump disassembly? [Re: Stanton] #1360325
12/29/12 02:27 PM
12/29/12 02:27 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Don't we have a "Worst of Posts" around here for postings like this??
Sometimes one really has to wonder about folks. Never have I heard of such a "backasswards" way of doing something. Why the cost alone one could get at least 3 impellers for the price of the re-build. Just don't get it? Then again maybe I'm not supposed to...
Re: BIG block water pump disassembly? [Re: CR8CRSHR] #1360326
12/29/12 02:48 PM
12/29/12 02:48 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Really??? Where is that banghead smilie when you need it?
Re: BIG block water pump disassembly? [Re: MPerry] #1360327
12/29/12 03:14 PM
12/29/12 03:14 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Actually never rebuilt one for a BB mopar but I did have to rebuild one for a Turbo charged Perkins Diesel engine. Kit was very expensive but I put it back in and logged 2200hrs more with no problems. I am sure it could be done but not cost effective. I had to do mine cause the replacement was in Germany and was a couple hundred dollars plus shipping and it broke on a friday. It was on a Grape harvestor and I needed to finish harvesting before a hurricane and luckily found the kit about 50 miles away at a parts depot....
Re: BIG block water pump disassembly? [Re: autoxcuda] #1360328
12/29/12 03:25 PM
12/29/12 03:25 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I am aware I can go down to my local auto parts store and buy a rebuilt water pump for $45.00. However my cars ( which I am the original owner for 40 plus years) still have their original water pumps. I am trying to keep the cars all original and the rebuilt pumps are not the same shape nor do they have the Chrysler casting number in them. I can have my alternator, power steering pump etc. rebuilt, why not the water pump. I just need to find someone who rebuilds water pumps preferably located in southern california. Thank you for any help.
Re: BIG block water pump disassembly? [Re: sbcjd] #1360329
12/29/12 03:35 PM
12/29/12 03:35 PM
sbcjd you certainly ain't getting much love on this request. I'm on your side & (some) people here do tend to get a bit owly especially on the weekends. Yeah if you can locate the seal assy I think you'd be well on your way or as said mark it on the inside where it dont show & find a rebuilder.
Re: BIG block water pump disassembly? [Re: CR8CRSHR] #1360330
12/29/12 03:49 PM
12/29/12 03:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The rebuilt parts store water pumps do not look at all like the original cast iron water pumps and do not have the same casting and date marks.
This is really a resto topic.
I'm sorry that people are too ignorant to understand someone else's perspective or opinions that do not match thier own.
Re: BIG block water pump disassembly? [Re: autoxcuda] #1360331
12/29/12 03:58 PM
12/29/12 03:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
its my daily deal down here
