Is there any reason #1360103
12/28/12 12:16 PM
12/28/12 12:16 PM
oregon
savoyracer Offline OP
oregon
That I should not cut my Indy valley plate lengthwise in half. The plate fits under the Indy heads, and the only way to remove it, is either take off a head, or unbolt everything off the front of the engine, and slide it forward. I was thinking that I can make it a two piece valley plate, and it would simply lift out, then I can remove my lifters easily to be checked out. Then to reinstall, simply run a silicone bead down the joint and it will be good until next time. Anything wrong with this thought?
Re: Is there any reason [Re: savoyracer] #1360104
12/28/12 12:34 PM
12/28/12 12:34 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Wouldn't it be easier to try and sell the one you have and buy the two piece set up ? Just my
Re: Is there any reason [Re: savoyracer] #1360105
12/28/12 12:43 PM
12/28/12 12:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
are you trying to take it out w/o removing the intake? if you cut it from back to front I'd think it would seal very well as it would not be very stable. They sell units that have access plates so you don't have to go thru all of that.
Coming soon!!!!
Re: Is there any reason [Re: Mr.Yuck] #1360106
12/28/12 12:57 PM
12/28/12 12:57 PM
oregon
oregon
............I will remove the intake, I just want to be able to get access to my lifters at that point without having to remove anything else. I have a machine shop here, that I use all the time, I was thinking of making the cut on a 45 degree angle, so it would simply slip back togather with silicone to seal it. Just don't know if this is a good idea or not.
Re: Is there any reason [Re: savoyracer] #1360107
12/28/12 02:17 PM
12/28/12 02:17 PM
I have a Bulldog two piece valley covers that is that way,I haven't used it yet so no valid input on how it works, sorry. I did try one of the two piece sheet metal steel valley covers , it didn't seal that well The single piece sheet metal steel valley cover that Koffels provides with there B1 kits could be slid out the front maybe, if you remove the distributor, I think I haven't used it yet either
Re: Is there any reason [Re: Cab_Burge] #1360108
12/28/12 02:21 PM
12/28/12 02:21 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We just mill enough off each side so that it can be installed and removed.The top of the angle remains the same and takes the same amont of silicone to seal,just add a little extra at each corner.
Re: Is there any reason [Re: B G Racing] #1360109
12/28/12 02:23 PM
12/28/12 02:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
here...
Re: Is there any reason [Re: Mr.Yuck] #1360110
12/28/12 02:28 PM
12/28/12 02:28 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
here...
Only problem it's twice the cost,and machining the sides only takes a little time.
Re: Is there any reason [Re: B G Racing] #1360111
12/28/12 02:39 PM
12/28/12 02:39 PM
okla.
sam64 Offline
sam64  Offline
okla.
i cut my indy plate right down the middle but at an angle,seems to be doin fine so far.did it on a shop band saw.
Re: Is there any reason [Re: 70dusterjohn] #1360112
12/28/12 02:48 PM
12/28/12 02:48 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
My Bulldog 2 piece was cut on a 45 degree
When we dyno'd it , it had a slight vac leak
had to take another couple thousands off and reseal
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Is there any reason [Re: sam64] #1360113
12/28/12 02:48 PM
12/28/12 02:48 PM
fresno ca
mikeysmopars Offline
fresno ca
I have more time than money so I cut out the center and mad a plate like the one Indy offers.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Is there any reason [Re: mikeysmopars] #1360114
12/28/12 03:10 PM
12/28/12 03:10 PM
This is what I was going to suggest.
Re: Is there any reason [Re: savoyracer] #1360115
12/28/12 03:16 PM
12/28/12 03:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The plate will come out as a one piece. Slide it slightly rearward, drop the front of the plate into the valley twist to one side and remove. I also tap the center holes in the plate 3/8",screw a bolt in till snug against the block. Helps break the seal at the front and rear china walls.
Doug
Re: Is there any reason [Re: savoyracer] #1360116
12/28/12 04:40 PM
12/28/12 04:40 PM
AndyF Offline
AndyF  Offline
I tried all of the cheap tricks too and then finally just started building my own valley plates from billet. I never had much luck with any of the low buck solutions. There was always a leak somewhere.
Re: Is there any reason [Re: AndyF] #1360117
12/29/12 09:40 AM
12/29/12 09:40 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
my Bulldog 2 piece never leaked...of course detail was used in the installation...plenty of sealant...
its been on 2 engines now..recently on the dyno...no leaks...
I would say find a set of Bulldog's....if thats the path you want to follow
Re: Is there any reason [Re: savoyracer] #1360118
12/30/12 12:27 AM
12/30/12 12:27 AM
oregon
oregon
Gotta love Moparts......Thanks everyone for the ideas. BG's idea seems to fit my situation very well.
Re: Is there any reason [Re: savoyracer] #1360119
12/30/12 01:05 AM
12/30/12 01:05 AM
Ontario, Canada
Hyper Henry Offline
Hyper Henry  Offline
Ontario, Canada
I tried just about every valley pan and all of them would leak Finally listened to Andy F and just went with MP 337 intake and have had no leaks ever since
Derrick
Re: Is there any reason [Re: savoyracer] #1360120
12/30/12 10:24 AM
12/30/12 10:24 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I only suggest it because we have done it on every engine we have done with the solid plate and the two piece plate.Even with the two piece Indy plate it is hard to inspect and remove the roller lifters through the removable plate.We have not experienced any leaks if properly sealed.We have seen leaks at the block rails when people try and slide the plate in place.Just cut enough that the plate can be started at a 45 degree angle and dropped in and make sure each corner is sealed.We have been doing it this way for over 12 years.
Re: Is there any reason [Re: savoyracer] #1360121
12/30/12 11:39 AM
12/30/12 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself, if I was going to make it removable I would
cut it length way but I would make it so it over laps
by welding a piece of alum to the lower part so you
end up with a 1" over lap so you can drill and tap
it for screws... put a bead of silicone on it and
tighten it up.... JMO.... if you have access to a mill
I would butt weld the piece and mill a step in both
parts to give the over lap and it would go out on
the china rails
Re: Is there any reason [Re: MR_P_BODY] #1360122
12/30/12 05:04 PM
12/30/12 05:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There is no disagreement with Mike and others,most all suggestions are viable.As for us we like to apply the KISS method to save time and money that can be well spent on other more important areas of engine assembly.Anyone can shave down the sides with minimum effort with a belt sander or mill or other means.Just shave the bottom edge straight and don't fuss with the top of the angle.These plates are not accurately cut to begin with.We see some that all we had to do was shave a little off each corner.
