Re: Is there any reason
[Re: Mr.Yuck]
#1360106
12/28/12 12:57 PM
12/28/12 12:57 PM
Posts: 446 oregon
savoyracer
oregon
are you trying to take it out w/o removing the intake? if you cut it from back to front I'd think it would seal very well as it would not be very stable. They sell units that have access plates so you don't have to go thru all of that.
............I will remove the intake, I just want to be able to get access to my lifters at that point without having to remove anything else. I have a machine shop here, that I use all the time, I was thinking of making the cut on a 45 degree angle, so it would simply slip back togather with silicone to seal it. Just don't know if this is a good idea or not.
[Re: savoyracer]
#1360107
12/28/12 02:17 PM
12/28/12 02:17 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I have a Bulldog two piece valley covers that is that way,I haven't used it yet so no valid input on how it works, sorry. I did try one of the two piece sheet metal steel valley covers , it didn't seal that well The single piece sheet metal steel valley cover that Koffels provides with there B1 kits could be slid out the front maybe, if you remove the distributor, I think I haven't used it yet either
[Re: Mr.Yuck]
#1360110
12/28/12 02:28 PM
12/28/12 02:28 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
here...
Only problem it's twice the cost,and machining the sides only takes a little time.
[Re: 70dusterjohn]
#1360112
12/28/12 02:48 PM
12/28/12 02:48 PM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
My Bulldog 2 piece was cut on a 45 degree
When we dyno'd it , it had a slight vac leak
had to take another couple thousands off and reseal
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: sam64]
#1360113
12/28/12 02:48 PM
12/28/12 02:48 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I have more time than money so I cut out the center and mad a plate like the one Indy offers.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#1360114
12/28/12 03:10 PM
12/28/12 03:10 PM
This is what I was going to suggest.
[Re: savoyracer]
#1360115
12/28/12 03:16 PM
12/28/12 03:16 PM
Posts: 9,835 MI, usa
dvw
MI, usa
That I should not cut my Indy valley plate lengthwise in half. The plate fits under the Indy heads, and the only way to remove it, is either take off a head, or unbolt everything off the front of the engine, and slide it forward. I was thinking that I can make it a two piece valley plate, and it would simply lift out, then I can remove my lifters easily to be checked out. Then to reinstall, simply run a silicone bead down the joint and it will be good until next time. Anything wrong with this thought?
The plate will come out as a one piece. Slide it slightly rearward, drop the front of the plate into the valley twist to one side and remove. I also tap the center holes in the plate 3/8",screw a bolt in till snug against the block. Helps break the seal at the front and rear china walls. Doug
[Re: savoyracer]
#1360120
12/30/12 10:24 AM
12/30/12 10:24 AM
B G Racing
Eighty Four, PA
Gotta love Moparts......Thanks everyone for the ideas. BG's idea seems to fit my situation very well.
I only suggest it because we have done it on every engine we have done with the solid plate and the two piece plate.Even with the two piece Indy plate it is hard to inspect and remove the roller lifters through the removable plate.We have not experienced any leaks if properly sealed.We have seen leaks at the block rails when people try and slide the plate in place.Just cut enough that the plate can be started at a 45 degree angle and dropped in and make sure each corner is sealed.We have been doing it this way for over 12 years.
[Re: savoyracer]
#1360121
12/30/12 11:39 AM
12/30/12 11:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Myself, if I was going to make it removable I would cut it length way but I would make it so it over laps by welding a piece of alum to the lower part so you end up with a 1" over lap so you can drill and tap it for screws... put a bead of silicone on it and tighten it up.... JMO.... if you have access to a mill I would butt weld the piece and mill a step in both parts to give the over lap and it would go out on the china rails
