Coil over spring rate #1359768
12/27/12 02:30 PM
12/27/12 02:30 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hi,
I'm installing ladder bars and coil over schocks on my 67 Barracuda....
What spings do I need ? 110 lbs ? 130 lbs ? 95 ?
Dan
Re: Coil over spring rate [Re: Wedgeman] #1359769
12/27/12 03:12 PM
12/27/12 03:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hi,
Dan
Its gonna depend on what the back of the car weighs
but usually its 110 to 120... if its heavy then 130 max
Re: Coil over spring rate [Re: MR_P_BODY] #1359770
12/27/12 03:41 PM
12/27/12 03:41 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Coil over spring rate [Re: MR_P_BODY] #1359771
12/27/12 03:49 PM
12/27/12 03:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Depending on the weight we usually see 130#/150# on Darts and Cudas that weigh 3000#/3200.These are wedge and hemi with automatics.
Re: Coil over spring rate [Re: W.I.N. Racing] #1359772
12/27/12 03:50 PM
12/27/12 03:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
110-120 would be a good starting point but if you go with QA-1 shocks, they will give you instruction as to how to set up for proper spring rate at your required ride height, that is how I did mine and it was also how Chassisman told me to do it and it works well.
Re: Coil over spring rate [Re: B G Racing] #1359773
12/27/12 04:08 PM
12/27/12 04:08 PM
My car had 170 lb srpings on the rear to start with,BB 1971 Duster, 3450 lbs, 1650 lbs on the back, I switch them to 150 lb. springs and that made the ride smoother, 130 lb springs would have probally been better but 1.39 60 ft. times foot braking my 727 made me grin
