Re: car ride height
[Re: earthmover]
#1359135
12/25/12 11:51 PM
12/25/12 11:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I always set them low... my car use to be 3.5" to the lowest part... NHRA says 3" minimum from the front to 18" behind the front spindle.. then 2" back... my car was a PITA to load on the trailer when it was that low so I raised it to 4"
Re: car ride height
[Re: MR_P_BODY]
#1359137
12/25/12 11:56 PM
12/25/12 11:56 PM
dartman366
Mt. Vernon, Ohio
looked for some pic's (no luck) from over the years as things changed and how it progressively got closer to the ground, started out with the old stink bug stance but more level and lower now,, and looks much better that way.
Re: car ride height
[Re: earthmover]
#1359139
12/26/12 12:21 AM
12/26/12 12:21 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I like them low!! Looks killer.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: car ride height
[Re: 1967dartgt]
#1359143
12/26/12 01:15 AM
12/26/12 01:15 AM
MR_P_BODY
Lets try this picture again
That previous pic was quite WEIRD
Re: car ride height
[Re: Deepockets]
#1359149
12/26/12 10:18 AM
12/26/12 10:18 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The more power you have the lower you can go, given big tires and good suspension. Shocking the tires with a transbrake helps get a low fast car up on the tires if the weight distribution is nose heavy. I have 53 percent on the front now and with a bit more rpm on launch, works great.
Re: car ride height
[Re: Crizila]
#1359153
12/26/12 01:20 PM
12/26/12 01:20 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Well we have one of both...Low and not so low. Both have been near 170 and handle just fine. ALthough we will be addressing the ride height on the small tire car before it comes back out next year.
