car ride height #1359134
12/25/12 11:42 PM
12/25/12 11:42 PM
nc
E
earthmover Offline OP
E
nc
what factor do you guys use to get your ride height on your car.. low in the weeds or low/high????my car as it is right now is about 6" from the bottom of the oil pan and I really like the way it look...I have always like the low race car look.
Re: car ride height [Re: earthmover] #1359135
12/25/12 11:51 PM
12/25/12 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always set them low... my car use to be 3.5" to
the lowest part... NHRA says 3" minimum from the front
to 18" behind the front spindle.. then 2" back... my
car was a PITA to load on the trailer when it was that
low so I raised it to 4"
Re: car ride height [Re: MR_P_BODY] #1359136
12/25/12 11:55 PM
12/25/12 11:55 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
My duster has always sat low up front, the rear was lowered and tucked a 275/60 really nicely but the car just plain old didn't work so up the rear end went and I haven't looked back yet.
Re: car ride height [Re: MR_P_BODY] #1359137
12/25/12 11:56 PM
12/25/12 11:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
looked for some pic's (no luck) from over the years as things changed and how it progressively got closer to the ground, started out with the old stink bug stance but more level and lower now,, and looks much better that way.
Re: car ride height [Re: dartman366] #1359138
12/26/12 12:15 AM
12/26/12 12:15 AM
nc
E
E
nc
thanks guys I was just wondering how most came up with the stance of there car... I really like my car the way it is now and see how it works out...may just have to make longer ramps for the trailer
Re: car ride height [Re: earthmover] #1359139
12/26/12 12:21 AM
12/26/12 12:21 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I like them low!! Looks killer.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: car ride height [Re: 1967dartgt] #1359140
12/26/12 01:03 AM
12/26/12 01:03 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I like the look of my dart lower as well.
Re: car ride height [Re: 1967dartgt] #1359141
12/26/12 01:05 AM
12/26/12 01:05 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Mine is in the weeds...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: car ride height [Re: 1967dartgt] #1359142
12/26/12 01:07 AM
12/26/12 01:07 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Lets try this picture again
Re: car ride height [Re: 1967dartgt] #1359143
12/26/12 01:15 AM
12/26/12 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That previous pic was quite WEIRD
Re: car ride height [Re: earthmover] #1359144
12/26/12 01:26 AM
12/26/12 01:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Here is a pic of the P-Body after I raised it up
Re: car ride height [Re: MR_P_BODY] #1359145
12/26/12 01:29 AM
12/26/12 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Here is a pic of the Rampage... it'll be a 1/2" lower
in the front when done
Re: car ride height [Re: MR_P_BODY] #1359146
12/26/12 01:29 AM
12/26/12 01:29 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
It's making me crop it and came out that way the first go around.
Re: car ride height [Re: earthmover] #1359147
12/26/12 02:27 AM
12/26/12 02:27 AM
I had my Duster as low as I could get the coil overs shocks set on the rear end brackest, put taller slicks on it and had to raise the back up to clear those tires, I ended up doing the ride hieght change with the car on the scales, absolutely no changes on the front to rear weight distrubution, absolutely no change I did see a change in the 60 fts and reaction times but I'm sure that was do to the tire size and rear gear ratio changes do to the 6 inch more circumference, not the ride hieght change Set it so YOU like it
Re: car ride height [Re: Cab_Burge] #1359148
12/26/12 09:07 AM
12/26/12 09:07 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
go low young man
Re: car ride height [Re: Deepockets] #1359149
12/26/12 10:18 AM
12/26/12 10:18 AM
gregsdart Offline
gregsdart  Offline
The more power you have the lower you can go, given big tires and good suspension. Shocking the tires with a transbrake helps get a low fast car up on the tires if the weight distribution is nose heavy. I have 53 percent on the front now and with a bit more rpm on launch, works great.
Re: car ride height [Re: gregsdart] #1359150
12/26/12 10:32 AM
12/26/12 10:32 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
With Big engines & lots of speed the lower cars handle better.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: car ride height [Re: MRMOPAR622] #1359151
12/26/12 10:57 AM
12/26/12 10:57 AM
Az
Crizila Offline
Crizila  Offline
Az
It's all about aerodynamics
Fastest 300
Re: car ride height [Re: Crizila] #1359152
12/26/12 01:19 PM
12/26/12 01:19 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
I like them to have a small rake/stance. Kinda low in the front with a little rise in the rear. Gives it a mean look.
Re: car ride height [Re: Crizila] #1359153
12/26/12 01:20 PM
12/26/12 01:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well we have one of both...Low and not so low. Both have been near 170 and handle just fine. ALthough we will be addressing the ride height on the small tire car before it comes back out next year.
