440 Intake Question. #1358344
12/24/12 05:53 AM
12/24/12 05:53 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Just bought a 77 D-100 with 440 auto. The previous owner installed an Edelbrock TM-7 intake using just the stock metal intake gasket. The problem I'm having is when it's fully warmed up, it won't stay running. I keeps missing and dropping cylinders until I bring up the rpm's.
I have always used the FelPro 1216 gaskets that sandwich the stock intake gasket when installing an aluminum manifold. Is it possible that my problem is a vacuum leak around the mating surface of the intake?
Re: 440 Intake Question. [Re: elmor] #1358345
12/24/12 08:44 AM
12/24/12 08:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some intakes will leak without the papers.We have ours that are aluminum installed with just the tins.No leaks.Just be aware that some of the thick papers will throw the bolt holes off.Easy to check start it and spray some carb cleaner aroubd the ports.Idle will change if its leaking.Rocky
Chrysler Firepower
Re: 440 Intake Question. [Re: therocks] #1358346
12/24/12 01:07 PM
12/24/12 01:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
We make some gaskets that are .015 thick, so they don't [Edited by Moparts - Family Friendly Site - Keep it clean] up the fit.
Re: 440 Intake Question. [Re: elmor] #1358347
12/24/12 06:17 PM
12/24/12 06:17 PM
it might be leaking on the bottom side. I'd pull it & add a THIN/EVEN coat of Permatex #1 in the toothpaste like tube to both sides of the 8 valley pan ports
Re: 440 Intake Question. [Re: RapidRobert] #1358348
12/24/12 06:31 PM
12/24/12 06:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the bottom is often over-looked cause you can't see it! out of sight, out of mind!
Re: 440 Intake Question. [Re: mikemee1331] #1358349
12/24/12 06:51 PM
12/24/12 06:51 PM
Chicago
PurpleBeeper Offline
Chicago
I chased a miss like this for a couple months.... I suggest you spray around with carb cleaner first (cheapest/easiest), inspect the carburetor (rebuild it if it's been sitting) and if those don't work, pull the intake.
Mine WAS leaking under the intake & I could see a little oil in the intake runners. Form-A-Gasket fixed mine.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 440 Intake Question. [Re: PurpleBeeper] #1358350
12/24/12 08:22 PM
12/24/12 08:22 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
The carb is new with less than 200 miles on it, out of the box, so I don't think that is the problem. The guy at my local speed shop said that you can often get away without the paper gasket on the head side of the valley pan, but that you are asking for trouble if you don't use them on the aluminum side. After looking a little closer, I'm not sure the seller even changed the intake gasket when he put on the new intake.
For what I paid for everything, I basically paid for the new parts he put on and the rest of the truck was free! lol Gaskets are cheap.
Thanks guys. Merry Christmas.
Re: 440 Intake Question. [Re: elmor] #1358351
12/24/12 09:11 PM
12/24/12 09:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Probably didn't - I have reused valley tins many times with out replacing - even when using an aluminum intake. cleaned all oil residue off and sprayed with a liberal coat of aluminum paint.
Re: 440 Intake Question. [Re: MoparforLife] #1358352
12/25/12 10:17 AM
12/25/12 10:17 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Back in the day they got reused a lot.They were like 30 to 40 bucks back then and that was a lot of $$$$.Ive reused them quite a bit with no sealer or problems.Both our BBs with aluminum intakes are run just tins.No problems.Intake is easy to pull and check for leaks.Rocky
Chrysler Firepower
Re: 440 Intake Question. [Re: therocks] #1358353
12/25/12 01:38 PM
12/25/12 01:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
While you have the intake off set the manifold down on the heads without the gasket and check the fit with a flashlight and or feeler gauges. There are some folks out there that still machine intakes to compensate for milled heads and that intake will ONLY fit the engine it was machined for.Unless that TM7 was fairly new I suspect that may be your problem Just something I have seen before
Gus
64 Plymouth Savoy
Dana 60
Re: 440 Intake Question. [Re: fourgearsavoy] #1358354
12/25/12 01:45 PM
12/25/12 01:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Gus, I've also seen them crooked new and that's what I mentioned in the other thread he started.
Link
https://board.moparts.org/ubbthreads/show...e=2#Post7516476
Re: 440 Intake Question. [Re: roadhazard] #1358355
12/25/12 02:18 PM
12/25/12 02:18 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Look at all of the machining required to get it correct. It is amazing some of them actually seal.
Re: 440 Intake Question. [Re: fourgearsavoy] #1358356
12/26/12 12:04 AM
12/26/12 12:04 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
Intake and carb were installed new and have less than 200 miles on them. Engine has 40,000 and has never had the heads off, so I don't believe anything has been milled. I used to sell auto parts for years and yes, I have seen many parts all fudged up right from the box. I am pulling the TM-7 and 600 cfm Edelbrock carb and bolting on a new Performer RPM and 750 Holley this weekend. I will re-use the valley pan and use FelPro MS 90175 paper gaskets. Should take care of the problem.
