Re: 440 Intake Question.
[Re: elmor]
#1358345
12/24/12 08:44 AM
12/24/12 08:44 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Some intakes will leak without the papers.We have ours that are aluminum installed with just the tins.No leaks.Just be aware that some of the thick papers will throw the bolt holes off.Easy to check start it and spray some carb cleaner aroubd the ports.Idle will change if its leaking.Rocky
Chrysler Firepower
[Re: elmor]
#1358347
12/24/12 06:17 PM
12/24/12 06:17 PM
RapidRobert
it might be leaking on the bottom side. I'd pull it & add a THIN/EVEN coat of Permatex #1 in the toothpaste like tube to both sides of the 8 valley pan ports
[Re: RapidRobert]
#1358348
12/24/12 06:31 PM
12/24/12 06:31 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
the bottom is often over-looked cause you can't see it! out of sight, out of mind!
[Re: mikemee1331]
#1358349
12/24/12 06:51 PM
12/24/12 06:51 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I chased a miss like this for a couple months.... I suggest you spray around with carb cleaner first (cheapest/easiest), inspect the carburetor (rebuild it if it's been sitting) and if those don't work, pull the intake.
Mine WAS leaking under the intake & I could see a little oil in the intake runners. Form-A-Gasket fixed mine.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: MoparforLife]
#1358352
12/25/12 10:17 AM
12/25/12 10:17 AM
therocks
Niles , Ohio
Back in the day they got reused a lot.They were like 30 to 40 bucks back then and that was a lot of $$$$.Ive reused them quite a bit with no sealer or problems.Both our BBs with aluminum intakes are run just tins.No problems.Intake is easy to pull and check for leaks.Rocky
Chrysler Firepower
[Re: therocks]
#1358353
12/25/12 01:38 PM
12/25/12 01:38 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
While you have the intake off set the manifold down on the heads without the gasket and check the fit with a flashlight and or feeler gauges. There are some folks out there that still machine intakes to compensate for milled heads and that intake will ONLY fit the engine it was machined for.Unless that TM7 was fairly new I suspect that may be your problem Just something I have seen before Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
