vac. pump and fuel pump big block motor plate #1357615
12/23/12 01:15 PM
12/23/12 01:15 PM
nc
E
earthmover Offline OP
E
nc
going to be running a toilet set up and a vac. pump any of you guys care to share any pics of how you mount all your stuff??? alter. as well if possible..
Re: vac. pump and fuel pump big block motor plate [Re: earthmover] #1357616
12/23/12 01:40 PM
12/23/12 01:40 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I don't know if I have any pictures but will check,might be best to buy the pump mount from Ron's it mounts on the passenger side of engine 2 bolts to the timing cover,mount the vacuum pump on the drivers side motor plate,finding room for the alt. might be a problem.But on a door car you might be able to space them out a little more for some extra space for the alt..
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: vac. pump and fuel pump big block motor plate [Re: MRMOPAR622] #1357617
12/23/12 02:05 PM
12/23/12 02:05 PM
nc
E
E
nc
ok that easy enough I got the mount but thought it would need to mount to the motor plate.. thank you sir.. that cuts back on the stress
Re: vac. pump and fuel pump big block motor plate [Re: earthmover] #1357618
12/23/12 02:44 PM
12/23/12 02:44 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
just up front of the motor plate works ok.
Re: vac. pump and fuel pump big block motor plate [Re: Deepockets] #1357619
12/23/12 03:00 PM
12/23/12 03:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No Fuel pump, but it would easily fit where the accumulator is. A word to the wise. Pulling vacuum from the fuel pump block off plate didn't work.
Doug
Re: vac. pump and fuel pump big block motor plate [Re: dvw] #1357620
12/23/12 03:46 PM
12/23/12 03:46 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Why didnt pulling vacuum from the fuel block off plate work for you? I had considered this, now I'm wondering. Was it pulling a lot of oil? Or to much windage?
Re: vac. pump and fuel pump big block motor plate [Re: Mopar-Al] #1357621
12/23/12 04:04 PM
12/23/12 04:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
There is just to much oil flying around in there with most typical Mopar oil pan set ups. There is a lot of oil in suspension in the typical Mopar engine with the pans most guys run to pull vac from there.
Re: vac. pump and fuel pump big block motor plate [Re: Al_Alguire] #1357622
12/23/12 04:08 PM
12/23/12 04:08 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I was thinking that might be the issue. That's why I had'nt bought it. I almost did yesterday, but thought I would have to make a shield for it. Then it got to deep in thought. I decided I was going to stay on top.
Re: vac. pump and fuel pump big block motor plate [Re: Mopar-Al] #1357623
12/23/12 10:59 PM
12/23/12 10:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I thought I'd be fine with A Jessel, no timing chain. I sucked oil at 4000 RPM just sitting in the garage. It has a aluminum pan with only 9 Qts. Level is plenty low. I moved it to the front of the rocker cover, we'll see how it works.
Doug
Re: vac. pump and fuel pump big block motor plate [Re: dvw] #1357624
12/24/12 12:56 AM
12/24/12 12:56 AM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
Does your pan have a kick out? Are you running a crank scaper?
My personal experience is the fuel plate is the best spot especially if you are pushrod oiling.
Re: vac. pump and fuel pump big block motor plate [Re: hvyweight] #1357625
12/24/12 08:36 AM
12/24/12 08:36 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The pan has a Kick out, a screen style scraper, and it is oiled thru the push rods. On initial fire up it filled the reservoir for the vacuum pump in about 10 minutes of running and puked it out the top. Thought it would be great location. The cam and crank (even though they are perfectly round in this area) must grab more oil than I would have thought.
Doug
Re: vac. pump and fuel pump big block motor plate [Re: dvw] #1357626
12/24/12 12:23 PM
12/24/12 12:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A side kick out pan and scraper are good starts. A PROPERLY designed pan goes a long way to control windage and oil in suspension in a BB Mopar but they need to be correctly designed pieces that control the oil. Most of the stuff we see is not designed very well and leave a lot to be desired.
Re: vac. pump and fuel pump big block motor plate [Re: dvw] #1357627
12/24/12 09:27 PM
12/24/12 09:27 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
Doug
How deep is the pan?
I had a deep Charlies pan when I had my 588 in the Plymouth. It was about 9 inches deep with a kick out. I ran about 7 quarts in that pan.
Now I have a dragster style in my Barracuda. It is 5.25 inches deep and I have the same problem as you. I am planning to add a kick out and a scaper.
I have talked to lots of people and they all agree get the oil away from the crank as far as possible.
Having a properly designed oil pan with a scraper and some form of a windage tray is the way to go.
BTW how much vaccumm are you trying to pull?
Mike
Re: vac. pump and fuel pump big block motor plate [Re: hvyweight] #1357628
12/25/12 12:48 PM
12/25/12 12:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I will set the vacuum at 12"-15"hg. It has a GZ kit. The pan is a Charlies with a though hole for the drag link. I forget hoe deep but it's a deep as could go in the car.
Doug
Re: vac. pump and fuel pump big block motor plate [Re: dvw] #1357629
12/25/12 12:50 PM
12/25/12 12:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The updated plumbing.
