Will my car stay with a #1357117
12/22/12 05:48 PM
12/22/12 05:48 PM
Ontario, canada
Mopar2ya Offline OP
Mopar2ya  Offline OP
Ontario, canada
72 Nova 454, 373 gears, turbo 400, i have a 425 hp 340 with 727 391 gears in a 66 Barracuda and does any one know what the big block Nova weights......Mopar2ya
Re: Will my car stay with a [Re: Mopar2ya] #1357118
12/22/12 06:16 PM
12/22/12 06:16 PM
Central NC
gch Offline
gch  Offline
Central NC
Depending on lightweight stuff he probably weighs around 3400lbs.If he has a strong motor and can hook you will have your hands full and likely see tail lights IMO.
Races arent won or lost on paper so go find out and let us know.
Re: Will my car stay with a [Re: Mopar2ya] #1357119
12/22/12 06:19 PM
12/22/12 06:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
are you sure you have 425 hp?
has your car ever been down the strip?
Tony
70 AARCuda Vitamin C
Re: Will my car stay with a [Re: 70AARcuda] #1357120
12/22/12 06:29 PM
12/22/12 06:29 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The Nova weighs more and certainly has more torque. The difference in a 1/4 mile race bwteen the two cars may be the ability to hook up where you might have the advantage...
Re: Will my car stay with a [Re: Jim_Lusk] #1357121
12/22/12 09:21 PM
12/22/12 09:21 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If your numbers are right, and both of you are on narrow tires I think you've got it made in the 1/8 th mile.
Not enough details on the nova to call the quarter mile though.
Anything else you can tell us?
Mo' Farts
Moderated by "tbagger".
Re: Will my car stay with a [Re: Mopar2ya] #1357122
12/23/12 02:11 PM
12/23/12 02:11 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You should be able to bury him unless that 454 is built nicely. The 340 64-66 Cuda combo was one of the better sleepers back in the day.
Sheldon
Re: Will my car stay with a [Re: RUNCHARGER] #1357123
12/23/12 02:21 PM
12/23/12 02:21 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sheldon
Good luck with that.
That BBC will eat your 340, imo.
Re: Will my car stay with a [Re: Challenger 1] #1357124
12/23/12 02:36 PM
12/23/12 02:36 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Depends on too many things. Line 'em up and burn 'em down. Yakkin' on the Internet ain't gonna get it done.
I had a 340 Swinger back in the early '80's that showed it's tail lights to a lot of pig block cars.
Just because they got big motors don't mean they can drive.
Re: Will my car stay with a [Re: slantzilla] #1357125
12/23/12 03:05 PM
12/23/12 03:05 PM
NJ
rth Offline
rth  Offline
NJ
If the Nova hooks I think you got a problem.
Re: Will my car stay with a [Re: Mopar2ya] #1357126
12/23/12 03:31 PM
12/23/12 03:31 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The guy with the better power to weight ratio will be faster. If the P/W ratios are close, traction and driver skill will be the difference. That Nova is probably very light. A bone stock 375/396 with headers and slicks will run 12.20s.
You have not given us anything on his set-up, and with limited info on your stuff, I don't have a lot of confidence in your 425 hp.
Re: Will my car stay with a [Re: Mopar2ya] #1357127
12/23/12 03:35 PM
12/23/12 03:35 PM
Is this a grudge match or will there be money in the pot
Re: Will my car stay with a [Re: RapidRobert] #1357128
12/23/12 05:44 PM
12/23/12 05:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Just make sure you got more guys around the car than he has on the starting line and you're golden.
Re: Will my car stay with a [Re: slantzilla] #1357129
12/23/12 07:35 PM
12/23/12 07:35 PM
Ontario, canada
Mopar2ya Offline OP
Mopar2ya  Offline OP
Ontario, canada
The 454 is stock, i just got this engine and the builder says its 425hp on paper, never been dyno'd. The Nova is my buddys car and it does run real well. My engine guy says the 340 should blow him away, but who knows until we get them out in the spring.
Re: Will my car stay with a [Re: Mopar2ya] #1357130
12/24/12 03:35 AM
12/24/12 03:35 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
A stock 454 you shouldn't have a problem.
My dads talked about my uncle and him racing way back. My dad was in a 70 Mach 1 with a 428 or 429(?) and my uncle in a 340 dart. Neither walked. Apparently pretty even race. Don't believe motors were much over stock
Re: Will my car stay with a [Re: 76dodgeboy] #1357131
12/24/12 03:40 AM
12/24/12 03:40 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If the 454 has oval port heads, you have a chance. If it has rectangular ports, you're done.
Re: Will my car stay with a [Re: B5 Bee] #1357132
12/24/12 03:53 AM
12/24/12 03:53 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Pretty close, it would be nice to know what stall you run as well size tires. You may have decent hp, but torque is the name of the ball game here. Also will this be a spirited street run or track run?
Street I give it to you with a decent driver mod.
Track, I might give it to him.
Need more info about both cars
Mike
Ps ain't bench racing fun!
1969 Dodge Dart Swinger
Re: Will my car stay with a [Re: Mopar2ya] #1357133
12/24/12 11:41 AM
12/24/12 11:41 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The 454 is stock,
That could change by spring !!
