What product to use to fasten stud to molding #1356445
12/20/12 09:21 PM
12/20/12 09:21 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
This is my C molding for the hood of my Runner. One of the studs came loose because the hole is worn and oversize. Which product should I use to fill the hole to hold the stud in place.
Thanks for the help
Re: What product to use to fasten stud to molding [Re: gygeneral] #1356446
12/21/12 02:17 AM
12/21/12 02:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
An epoxy compatible with the C moulding , I'd look at JB weld ???
Re: What product to use to fasten stud to molding [Re: gygeneral] #1356447
12/21/12 10:34 AM
12/21/12 10:34 AM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Loctite 609
Re: What product to use to fasten stud to molding [Re: ct440rod] #1356448
12/21/12 03:03 PM
12/21/12 03:03 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Go to the local pro paint shop and look at the SEM line of products.
http://semproducts.com/product-catalog/repair-materials/dual-mix/adhesives/
I'd also look into how to do this so that the stud can be removed, VS gluing it in permanently.
Re: What product to use to fasten stud to molding [Re: gygeneral] #1356449
12/21/12 05:07 PM
12/21/12 05:07 PM
alberta
Publicbottle Offline
alberta
3m scotch weld!
or
Devcon
Re: What product to use to fasten stud to molding [Re: Publicbottle] #1356450
12/22/12 08:04 AM
12/22/12 08:04 AM
None
71rm23 Offline
71rm23  Offline
None
Good suggestions. Another is 9309 used in aviation
Re: What product to use to fasten stud to molding [Re: 71rm23] #1356451
12/22/12 10:31 AM
12/22/12 10:31 AM
Ont, Canada
Ont, Canada
Thanks everyone, lots of ideas, I will research some of these as I have not heard of some of them.
