Protecting header coatings during installation.. #1355568
12/19/12 04:10 PM
12/19/12 04:10 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Anybody got any tips? I plan on having my headers coated but they are hard to install without bumping SOMETHING during the process...you all know how roomy a-bodies are lol. Any kind of protective tape or ideas?
Re: Protecting header coatings during installation.. [Re: Hot 340] #1355569
12/19/12 04:14 PM
12/19/12 04:14 PM
Renton Washington
Triple Threat Offline
Renton Washington
Saran Wrap?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Protecting header coatings during installation.. [Re: Hot 340] #1355570
12/19/12 04:18 PM
12/19/12 04:18 PM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
I just took an old bed sheet and wrapped it around the header when I lifted the header up into the engine bay. Easy solution and it worked out great, no scratches or marks.. also makes it easier if you have another set of helping hands...
Re: Protecting header coatings during installation.. [Re: Hot 340] #1355571
12/19/12 05:46 PM
12/19/12 05:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Towels or anything like it.... BUT the coating is
harder than the paint job so cover the paint instead
of the headrs
Re: Protecting header coatings during installation.. [Re: MR_P_BODY] #1355572
12/19/12 05:55 PM
12/19/12 05:55 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I had good luck with a pillow case. You can pull it off after they are up in position.
Re: Protecting header coatings during installation.. [Re: DJVCuda] #1355573
12/20/12 09:58 AM
12/20/12 09:58 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks guys...
Re: Protecting header coatings during installation.. [Re: Hot 340] #1355574
12/20/12 12:49 PM
12/20/12 12:49 PM
Az
Crizila Offline
Crizila  Offline
Az
Duct tape on all the header pipe peripheral edges and exposed corners/ bends.
Fastest 300
Re: Protecting header coatings during installation.. [Re: Crizila] #1355575
12/20/12 01:54 PM
12/20/12 01:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Duct tape is what i use too. Run it long ways with the pipes on all pipe curves.
