Brake Nuts, Red Color #1354853
12/18/12 10:49 AM
12/18/12 10:49 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Any recommendation for correct looking paint, varnish, dye, or other for the red nuts used on MOPAR brake components?
Thanks for the input
Re: Brake Nuts, Red Color [Re: AAR#2] #1354854
12/18/12 03:34 PM
12/18/12 03:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They are not painted ...
Re: Brake Nuts, Red Color [Re: JohnRR] #1354855
12/18/12 04:42 PM
12/18/12 04:42 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Nope, not anodize, as anodize is a process primarily for aluminum. While there are several materials other than aluminum, steel is not one of them.
Re: Brake Nuts, Red Color [Re: JohnRR] #1354856
12/18/12 04:48 PM
12/18/12 04:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
They are anodized ...
I respectively dis-agree.
The red coloring is red di-chrommate dip process - It's a secondary step done after the initial zinc plating process.
The red prop valve mounting nut / park brake adjuster flange nut is avail.
The power booster +/or master cylinder mounting kepps lock nuts in red are not.
Ok, back to work.
ps, I don't know of anyone who is capable of the red di-chromate process.
Maybe pm Jules,, he might.
The last wiper motor I got from him had a red nut for the crank arm included( sorry, didn't pay enough attention to see if it was plated or painted. And it didn't really matter to me as it can't be seen once installed)
pss, Duplicolor has a clear red that might work in a pinch.
Re: Brake Nuts, Red Color [Re: gtx6970] #1354857
12/18/12 05:34 PM
12/18/12 05:34 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
OK, Red Chromate is totally plausible. Only issue being I have never seen or run across anyone who sells it or offers the service. I'll check a few of the plating threads to see if its out there
I toyed with using Dykem Red but would prefer to do what's right if I can find the material
Re: Brake Nuts, Red Color [Re: AAR#2] #1354858
12/18/12 06:02 PM
12/18/12 06:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So that I got the process incorrect, I knew that they were not painted.
Re: Brake Nuts, Red Color [Re: AAR#2] #1354859
12/18/12 10:32 PM
12/18/12 10:32 PM
cbusters Offline
cbusters  Offline
Try some of the Candy Red colored paint. It are more transparent than regular red paint.
Re: Brake Nuts, Red Color [Re: cbusters] #1354860
12/19/12 11:30 AM
12/19/12 11:30 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
And don't worry about consistency either as the degree of color changed from batch to batch.
Re: Brake Nuts, Red Color [Re: Stanton] #1354861
12/19/12 07:36 PM
12/19/12 07:36 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
"Duplicolor has a clear red that might work in a pinch. "
That is what I use.
I do have the nuts plated first in clear zinc. Then use the clear red.
The plating shop I use does not do red zinc. Wish they did though.
Jules
Re: Brake Nuts, Red Color [Re: JulesdaWiperman] #1354862
12/19/12 07:59 PM
12/19/12 07:59 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks Jules, I remember you saying that in the past but have not been so lucky to find, maybe a bit more searching.
As for red dichromate or chromate, I've had some in my industry searching with no success. Beginning to wonder if its not a snipe hunt.
Re: Brake Nuts, Red Color [Re: JulesdaWiperman] #1354863
12/19/12 08:01 PM
12/19/12 08:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is what I use.
Jules
its good i guess that it's an available color if it chips on install ?
Re: Brake Nuts, Red Color [Re: JohnRR] #1354864
12/19/12 09:06 PM
12/19/12 09:06 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
That is what I use.
Jules
The thinner the coat the better and then you still need to use some thin plastic{as in baggie} between the nut and socket...Krylon also has a line of the colored tints designed to be used over a silver base...It's their "X metals" line... link ...For some reason the link is'nt showing yellor or orange but I have those colors also...
Re: Brake Nuts, Red Color [Re: screamindriver] #1354865
12/19/12 09:37 PM
12/19/12 09:37 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks Guys, all good ideas and certainly I should be able to find one of them, after all were talking about nuts that are difficult at best to see, maybe more for me than anyone.
I've toyed with leaving them as is but they seem a bit weak . . . .
Re: Brake Nuts, Red Color [Re: AAR#2] #1354866
12/20/12 09:37 AM
12/20/12 09:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
... after all were talking about nuts that are difficult at best to see ...
all the more reason to go the extra mile making them correct
Re: Brake Nuts, Red Color [Re: JohnRR] #1354867
12/20/12 01:24 PM
12/20/12 01:24 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I spent more time and money on parts that will never bee seen unless the car is taken apart. Some people said I was crazy and who would know? ....I said, *I* would know.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Brake Nuts, Red Color [Re: JohnRR] #1354868
12/20/12 01:30 PM
12/20/12 01:30 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Try this...
Paint them with a off color red paint and then....while there still kinda wet, dip them in paint thinner till the paint starts to run. When there dry spray then with a flat clear paint and your done. I have done this a few times and it works very well.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Brake Nuts, Red Color [Re: Troy] #1354869
12/20/12 03:22 PM
12/20/12 03:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not all of them were red.
I pulled an original master cylinder out of a 1969 Roadrunner last year and the kepps nuts were yellow zinc,, No red plating of any kind
your mileage will vary
Re: Brake Nuts, Red Color [Re: DPelletier] #1354870
12/20/12 03:52 PM
12/20/12 03:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Those people are spot on with their assessment ...
Re: Brake Nuts, Red Color [Re: JohnRR] #1354871
12/20/12 04:28 PM
12/20/12 04:28 PM
super gas
super gas
I respectfully disagree JohnRR.
I look for little deatils when checking a car because
if those are done then anything else that the owner said he did is
most likely true. Guys that go around and say they did a " nut and bolt" restoration
and you see obvious signs of cutting corners are the ones I strongly question.
If I look under a dash and see loads of details, I am pretty sure the engine, tranny and diff
have been rebuilt properly and not just words to sugar up the car.
I am not implying that it is everybodies cup of tea to go that extra mile but it is nice to see.
For example why restores these. They usually never break and will never be seen.
Jules
Re: Brake Nuts, Red Color [Re: JulesdaWiperman] #1354872
12/20/12 04:29 PM
12/20/12 04:29 PM
super gas
super gas
Notice I did the red on the spring after it was plated clear zinc.
Jules
