70-71 3/4 ton truck...440 power???? #1354626
12/17/12 11:42 PM
12/17/12 11:42 PM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
I put out a want ad for a 440 and a guy responded that he has one in a 70 or 71 3/4 ton truck. he wants $250, but I just had a brain fart and remembered that they didn't come with 440's till 72. Am I right?
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: 70-71 3/4 ton truck...440 power???? [Re: gregsrt] #1354627
12/18/12 12:14 AM
12/18/12 12:14 AM
vashon island washington
hunterstroble Offline
Been many years for someone to swap one in. Have him read the block numbers to you.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: 70-71 3/4 ton truck...440 power???? [Re: hunterstroble] #1354628
12/18/12 12:36 AM
12/18/12 12:36 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep, largest stock engine would be a 383 2-bbl, but the 440 could have been swapped in.
JB Rhinehart, Realist
A-Body's RULE!
Re: 70-71 3/4 ton truck...440 power???? [Re: Rhinodart] #1354629
12/18/12 01:12 AM
12/18/12 01:12 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
thanks guys. its still in the truck so I'll have to tell him to get him to check the ID pad by the dist
Re: 70-71 3/4 ton truck...440 power???? [Re: gregsrt] #1354630
12/18/12 11:19 AM
12/18/12 11:19 AM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
That's the best bet. I've had many folks tell me about their "440" in their trucks only to find 400s and 383s when I checked them out...
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 70-71 3/4 ton truck...440 power???? [Re: AdventurerSport] #1354631
12/18/12 12:13 PM
12/18/12 12:13 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If it is a 440 then the info will be on the pad in front of the intake on the drivers side.
A-Body's RULE!
Re: 70-71 3/4 ton truck...440 power???? [Re: AdventurerSport] #1354632
12/18/12 12:14 PM
12/18/12 12:14 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lot of guys swapped in 440s or 413s into pick up trucks....before they had factory versions.
Re: 70-71 3/4 ton truck...440 power???? [Re: Joesixpack] #1354633
12/18/12 03:16 PM
12/18/12 03:16 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I agree, the 440 is one of the most common swaps into a 61-71 Dodge truck. It is definitely the most common swap for an engine that wasn't available in 61-71 trucks, the Cummins being second.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 70-71 3/4 ton truck...440 power???? [Re: Soopernaut] #1354634
12/18/12 11:54 PM
12/18/12 11:54 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
383 and 400 were options. In earlier years the 426 wedge was an option (IIRC). And I've been told that in the last year of the Swepty a 440 was an option but I don't think anyone has ever seen a factory 440 '71 Swepty.
I bought my '68 Swepty with a 440 in it but the 440 and matching trans was from a c-body.
The biggest problem are the engine mounts. The same isolator was used for a /6. It was never meant to hold a 440. I'm working on installing a set of locking mounts and a torque strap. I've now replaced 1 too many radiators.
Re: 70-71 3/4 ton truck...440 power???? [Re: Chilort] #1354635
12/19/12 12:13 AM
12/19/12 12:13 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
I just want the engine nothing from the truck. Although he said I could have it all for the same price. Just don't have the room.
Re: 70-71 3/4 ton truck...440 power???? [Re: gregsrt] #1354636
12/19/12 12:59 AM
12/19/12 12:59 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
You could probably get $250 for scrap value on the rest of the truck......Total cost of 440...$0.00
Re: 70-71 3/4 ton truck...440 power???? [Re: 6pkaar] #1354637
12/19/12 01:23 AM
12/19/12 01:23 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I would scrap the engine and keep the truck!
A-Body's RULE!
Re: 70-71 3/4 ton truck...440 power???? [Re: Chilort] #1354638
12/20/12 11:49 AM
12/20/12 11:49 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
The 400 wasn't an option in 70-71. The 383 was the only big block available in the light duty trucks. The 426 was a special option in 64,65 and 66. It was part of the High Performance Package.
If you get the whole truck, post some pictures. You might be able to make some money on some of the hard to find parts, provided anything is savable.
Re: 70-71 3/4 ton truck...440 power???? [Re: Soopernaut] #1354639
12/20/12 04:42 PM
12/20/12 04:42 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
check it out....i have seen early trucks with E& F440HP2 engines in them....seems those old 383 2bbls give up after 125K or so or they run them out of oil and spin bearings, dropping a 440 that you had pulled from a wrecked 69 or 70 Charger R/T .... yep seen it done
