Potential converter issue on 92 Dakota! #1352964
12/17/12 01:34 PM
12/17/12 01:34 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Guys, I am having a trans built for my Dakota, a 92 with the 5.2 and A518.
I was thinking it might be a good plan to change the flexplate, then found out that with the crank sensor I cant easily do that with my MP flexplate I have.
The biggest question I have now is, will the MP stall converter fit the stock Dakota flexplate?
IIRC the mopar converters use the small pattern for the converter mounting. This works for some stock applications, but in the past on my last two 440 projects it wasn't so.
The 440's both had a larger bolt pattern on the stock converters.
The converter I plan to use is no longer in production, and cannot get exact bolt pattern specs, and since its not here to inspect I would just be drawing at straws to guess.
So if anyone has any pointers on where to find the stock converter bolt circle diameter that would be very helpful.
Also what converter to flex plate bolts will I use?
It seems that there are two different size if memory serves me. There was a 5/16 and a 7/16 or am I having an early senior moment?
And lastly, as long as the trans is out, should I install a new crank sensor? I have no idea the age of the existing one, and don't know how long they typically last. The truck has 131K on the clock, and wasn't maintained the best in the last 6-7yrs.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Potential converter issue on 92 Dakota! [Re: hp383] #1352965
12/18/12 12:21 AM
12/18/12 12:21 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Re: Potential converter issue on 92 Dakota! [Re: hp383] #1352966
12/20/12 12:10 AM
12/20/12 12:10 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I guess I have been shunned...
Re: Potential converter issue on 92 Dakota! [Re: hp383] #1352967
12/20/12 12:36 AM
12/20/12 12:36 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Without the converter in hand we are guessing just like you. It's hard to give advice with very few facts.
Re: Potential converter issue on 92 Dakota! [Re: stumpy] #1352968
12/20/12 01:29 AM
12/20/12 01:29 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Im just trying to find specs on the stock converter bolt pattern.
And if anyone has used the MP 166K converter they may know the bolt size and pattern.
I will have the converter in hand Saturday. But would still like to find out the stock converter info.
Re: Potential converter issue on 92 Dakota! [Re: hp383] #1352969
12/20/12 10:42 AM
12/20/12 10:42 AM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
All wide gear 727/518 converter share the same bolt pattern up till 1996, when they were still the small pattern but went to a 90 degree spacing as opposed to the old offset spacing. The 440 converters you must have used would have been narrow ring gear 12 inch types with the larger pattern.The Mopar performance converters will have the small bolt pattern just like your 1992 518 and use a 5/16 bolt
Re: Potential converter issue on 92 Dakota! [Re: Greg Ducato] #1352970
12/20/12 02:13 PM
12/20/12 02:13 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Thats great news!
Thank you!
