Re: 521 procharged BB tips
[Re: RoadSkinner]
#1352836
12/17/12 12:13 AM
12/17/12 12:13 AM
Posts: 1,020 Andrews,In. U.S.of A.
67_Satellite
A tip you ask? The best advice you can get?From a guy putting 15 lbs. of boost on a stock bottom end with cast pistons for 3 summers:DON'T DETONATE IT!!!! Old recycled junk like i have,or real racecar parts,it's all the same physics. Go conservative on the timing and have a happy life. 8:1, 15 LBS., 21 deg total intercooled,no drama. http://www.youtube.com/watch?v=BVlmtgYb72U
[Re: Blown 68 R/T]
#1352842
12/17/12 10:01 PM
12/17/12 10:01 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Give Bob(Bigtimeauto)or Steve Morris a call.I did a LOT of research before i switched from roots to an F2.
and when you call 1 of them have all your info down that you can get from port size,flow...
[Re: RoadSkinner]
#1352846
12/18/12 09:22 AM
12/18/12 09:22 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
lol......yeah we ll c......whats the best way to tune an E85 blowe thru combo.....do u guys use EGT ...OR like a datapack.....
Give Scott at SDCE a call. He set my carb up and it was good right out of the box. I might have jetted the rears a size or two, but It was Go to Go. He will need all of your engine/car specs. http://www.sd-concepts.com/documents/moparsuperchargerkits.pdf
[Re: RoadSkinner]
#1352847
12/18/12 11:25 AM
12/18/12 11:25 AM
Clanton
northern,Ohio,USA
You will need an O2 forsure depending on the $$ you have for the rest.
