521 procharged BB tips #1352834
12/16/12 11:20 PM
12/16/12 11:20 PM
Upper Sandusky, Ohio
RoadSkinner Offline OP
Im building a 521 inch BB mopar , with a F1r procharger on it ,i know the blower is a little small but its what i got for now ..... got the block done , 9 to 1 compression ,going with a solid roller cam ,whos good at grinding a cam for my setup ...and any tips on a comvertor ....i have a set of fully ported Max wedge ported aluminum heads and a super victor intake , dominator flange ...any tips would b great ,this is my first blower motor .....thanks
Re: 521 procharged BB tips [Re: RoadSkinner] #1352835
12/16/12 11:24 PM
12/16/12 11:24 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Steve Morris is a good guy to call for a cam. Awesome customer service and support
Re: 521 procharged BB tips [Re: RoadSkinner] #1352836
12/17/12 12:13 AM
12/17/12 12:13 AM
Andrews,In. U.S.of A.
67_Satellite Offline
A tip you ask? The best advice you can get?From a guy putting 15 lbs. of boost on a stock bottom end with cast pistons for 3 summers:DON'T DETONATE IT!!!! Old recycled junk like i have,or real racecar parts,it's all the same physics. Go conservative on the timing and have a happy life. 8:1, 15 LBS., 21 deg total intercooled,no drama. http://www.youtube.com/watch?v=BVlmtgYb72U
Re: 521 procharged BB tips [Re: 67_Satellite] #1352837
12/17/12 02:20 AM
12/17/12 02:20 AM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
ill add... having home built a 630 wheel blowthrough v6 on e85, if its going to be carbed call kevin at CSU. the other guys stuff is over complicated.. and i agree on the timing.. keep a handle on it! mine was e85 on a true 11.0 engine but i ran 30 locked out!!
74 dart sport 440 www.Csucarbs.com
Re: 521 procharged BB tips [Re: RoadSkinner] #1352838
12/17/12 10:13 AM
12/17/12 10:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The converter will have a lot to do with your cam, operating range (power band) and gear selection. Once you get the cam/gear figured out call Turbo Action. I would also recommend a Snow Performance Meth/Water injection kit. It's an easy install and can save your pistons. It also allows you to run 93 instead of 110. You also might want to consider an MSD boost delay box. This allows you to adjust the timing. Say you have it set for 36* you can drop up to 4* per lb of boost.
As for a cam grinder... There are a bunch that can get the job done. Scott Brown comes to mind...
Coming soon!!!!
Re: 521 procharged BB tips [Re: RoadSkinner] #1352839
12/17/12 11:18 AM
12/17/12 11:18 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have a comp cam roller in mine and it was an off the shelf grind and you should be able to find something to fit your needs.I have been using a PTC vert 9.5 and has been very reliable.I am sure you will have lots of fun making boosted HP.
Re: 521 procharged BB tips [Re: Clanton] #1352840
12/17/12 08:53 PM
12/17/12 08:53 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Give Bob(Bigtimeauto)or Steve Morris a call.I did a LOT of research before i switched from roots to an F2.
Re: 521 procharged BB tips [Re: Blown 68 R/T] #1352841
12/17/12 09:13 PM
12/17/12 09:13 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Some good advise right there
I have a small comp roller and a Pro Torque converter,your gunna need a comp licence
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 521 procharged BB tips [Re: Blown 68 R/T] #1352842
12/17/12 10:01 PM
12/17/12 10:01 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
and when you call 1 of them have all your info down that you can get from port size,flow...
Re: 521 procharged BB tips [Re: Clanton] #1352843
12/17/12 11:41 PM
12/17/12 11:41 PM
thanks. guys ....all great advice....it will b on E85 vai a 1050 dominator.....and rhe car has 4.56 gears now....but i was thknking 4.10 gear....tire is ax32 14x32
Re: 521 procharged BB tips [Re: RoadSkinner] #1352844
12/18/12 12:09 AM
12/18/12 12:09 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
^^^^ That will get you to about 140 mph if you try just a little.
Re: 521 procharged BB tips [Re: Clanton] #1352845
12/18/12 01:34 AM
12/18/12 01:34 AM
lol......yeah we ll c......whats the best way to tune an E85 blowe thru combo.....do u guys use EGT ...OR like a datapack.....
Re: 521 procharged BB tips [Re: RoadSkinner] #1352846
12/18/12 09:22 AM
12/18/12 09:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Give Scott at SDCE a call. He set my carb up and it was good right out of the box. I might have jetted the rears a size or two, but It was Go to Go. He will need all of your engine/car specs. http://www.sd-concepts.com/documents/moparsuperchargerkits.pdf
Re: 521 procharged BB tips [Re: RoadSkinner] #1352847
12/18/12 11:25 AM
12/18/12 11:25 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You will need an O2 forsure depending on the $$ you have for the rest.
Re: 521 procharged BB tips [Re: Clanton] #1352848
12/19/12 01:40 AM
12/19/12 01:40 AM
im building my own blow thru dominator...i build carbs as a side job...but thanks for the tip.....ill do o2 s forsure...thanks
Re: 521 procharged BB tips [Re: RoadSkinner] #1352849
12/19/12 02:15 AM
12/19/12 02:15 AM
You really need a E85 tester, I've seen the same brand of E85 vary from 70% to 90%, depending on the time of the year That will really goof up your mixture, especially under pressure
Re: 521 procharged BB tips [Re: Cab_Burge] #1352850
12/19/12 03:20 AM
12/19/12 03:20 AM
yeah.....i know theres a summer grade n a winter grade...but ive never ran e85 on a blown motor......should b fun...
Re: 521 procharged BB tips [Re: RoadSkinner] #1352851
12/19/12 11:00 AM
12/19/12 11:00 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I went with a longer duration cam to help on the dynamic cr.[260/269 @ .050].646/.631exh.What size headers do you have?
Re: 521 procharged BB tips [Re: Clanton] #1352852
12/19/12 11:14 AM
12/19/12 11:14 AM
i have 2 inch Pro Parts headers ...i had a procharger on my RoadRunner for awhile , n had problems with over heating ...but i think the cam and no innercooler had alot to do with it , wasnt a blower cam ..have anyone had any problem with overheating ...
