Who uses a beadlock wheel?
#1352664
12/16/12 05:03 PM
12/16/12 05:03 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Did you see an gains in 60' doing this? Did the rotating weight it add matter or make any difference?
Shawn Jennings
Re: Who uses a beadlock wheel?
[Re: 64hemi330sedan]
#1352667
12/17/12 12:12 PM
12/17/12 12:12 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Beadlocks are heavy. Does your tire manufacturer make a beadlock tire in the size you want? I doubt you are going to see an improvment in 60' by adding over 10 lbs to your rotating weight.
2011 Drag Pak Challenger
[Re: rickseeman]
#1352668
12/17/12 12:29 PM
12/17/12 12:29 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Well they are on our small tire car. However look at 99% of the Comp Eliminator or the faster SS cars and see how many of them are using them? It will ad weight in the worst place possible and that is rotating weight. You also wont find them in the alcohol classes either. They are popular in TS and TD as well as S/G, but are they needed or make the car any better/quicker, IMO that is debateable
[Re: bigtimeauto]
#1352670
12/17/12 05:44 PM
12/17/12 05:44 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I don't have them on my car yet but on my buddies D/R Chevelle he lost nothing in the 60'. He used to have occasionally tire shake that shook so hard the it would trip the on off switch. Since installing the beadlocks it has never shook the tires once & also is now much more consistant.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: MegaDart]
#1352676
12/18/12 08:16 PM
12/18/12 08:16 PM
572_dup2
Salina ks
I use 15x12 now. tried tubes before but it 60s better without them. Just wondered if the little extra weight on rear tires would help. Logger shows im sitting spining just a little
Shawn Jennings
