Who uses a beadlock wheel? #1352664
12/16/12 05:03 PM
12/16/12 05:03 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
Did you see an gains in 60' doing this? Did the rotating weight it add matter or make any difference?
Shawn Jennings
Re: Who uses a beadlock wheel? [Re: 572_dup2] #1352665
12/16/12 05:41 PM
12/16/12 05:41 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Made no difference on mine. They add a few lbs but being able to change tires any time you want, wherever you want makes it worth the cost. My buddy does them here is a link.
http://www.beadlockconversions.com/
One day I will have something cool here.
Re: Who uses a beadlock wheel? [Re: sdaurity] #1352666
12/17/12 01:02 AM
12/17/12 01:02 AM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
if you are using tubes now you may notice a little improvement with the bead locks.but as stated in the second post they are great for the ease to change a tire but do add a little weight.
Re: Who uses a beadlock wheel? [Re: 64hemi330sedan] #1352667
12/17/12 12:12 PM
12/17/12 12:12 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Beadlocks are heavy. Does your tire manufacturer make a beadlock tire in the size you want? I doubt you are going to see an improvment in 60' by adding over 10 lbs to your rotating weight.
2011 Drag Pak Challenger
Re: Who uses a beadlock wheel? [Re: rickseeman] #1352668
12/17/12 12:29 PM
12/17/12 12:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well they are on our small tire car. However look at 99% of the Comp Eliminator or the faster SS cars and see how many of them are using them? It will ad weight in the worst place possible and that is rotating weight. You also wont find them in the alcohol classes either. They are popular in TS and TD as well as S/G, but are they needed or make the car any better/quicker, IMO that is debateable
Re: Who uses a beadlock wheel? [Re: Al_Alguire] #1352669
12/17/12 02:50 PM
12/17/12 02:50 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Liners weigh even more than beadlocks.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Who uses a beadlock wheel? [Re: bigtimeauto] #1352670
12/17/12 05:44 PM
12/17/12 05:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I don't have them on my car yet but on my buddies D/R Chevelle he lost nothing in the 60'. He used to have occasionally tire shake that shook so hard the it would trip the on off switch. Since installing the beadlocks it has never shook the tires once & also is now much more consistant.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Who uses a beadlock wheel? [Re: 6PKRTSE] #1352671
12/17/12 06:02 PM
12/17/12 06:02 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Beadlocks are the BOMB!!
Trying to find some reasonably priced 15x14 but not many around!
My dragster was more consistant when I switched to beadlocks. IMO it liked the extra weight directly on the contact patch...
I may have to give your conversion buddy a call!!
Re: Who uses a beadlock wheel? [Re: MegaDart] #1352672
12/17/12 06:09 PM
12/17/12 06:09 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Who uses a beadlock wheel? [Re: Triple Threat] #1352673
12/18/12 11:13 AM
12/18/12 11:13 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
http://cwibeadlock.com/dragraceconversions.htm
Also an option.
Ya thanks, much better prices there!!
Seriously considering single beadlock so I can change my own tires.
Re: Who uses a beadlock wheel? [Re: MegaDart] #1352674
12/18/12 11:25 AM
12/18/12 11:25 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Also an option.
you would still have to break down the other bead. Single beadlock just confuses the tire. Dbbl or nothing
Re: Who uses a beadlock wheel? [Re: bigtimeauto] #1352675
12/18/12 02:33 PM
12/18/12 02:33 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I wondered about that. Breaking a bead is no issue but don't want to confuse my tires!!lol
At that point I would just buy new and sell what I have to offset the cost... Problem for me is 15x15 is too big. Have not found any 15x14. Wonder what a 14-14.5 tire would do on a 15x12 beadlock??
Re: Who uses a beadlock wheel? [Re: MegaDart] #1352676
12/18/12 08:16 PM
12/18/12 08:16 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I use 15x12 now. tried tubes before but it 60s better without them. Just wondered if the little extra weight on rear tires would help. Logger shows im sitting spining just a little
Shawn Jennings
