Page 1 of 3 1 2 3
TIMING QUESTION #1351796
12/15/12 07:40 PM
12/15/12 07:40 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
How high have you been?
THe higher i go the faster it goes, where should i stop?
....BAD A$$ STREET CAR.....
Re: TIMING QUESTION [Re: n20mstr] #1351797
12/15/12 07:46 PM
12/15/12 07:46 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i would stop at 68 at 69 she might blow a rod.
Re: TIMING QUESTION [Re: n20mstr] #1351798
12/15/12 10:54 PM
12/15/12 10:54 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
On the motor or on spray? (If motor only, DON'T ask SSR!!) What's the A/F ratio now?
If you're spraying it, you tune it EXACTLY like it's on just nuts....start out with the timing conservative....keep leaning it out until it stops gaining trap speed...AND THEN add timing 1 degree at a time until it stops gaining trap speed...you want to run as little timing as possible and run the best trap speed...
There is only one thing that will kill a motor...detonation...and there are only three things that cause it....Too much timing...Not high enough octane fuel for the amount of cylinder pressure you're making...or oil getting into the combustion process somehow...usually passed the rings from running way too rich or out of round cylinders or passed the intake gasket or valve guides...
Thank me later...
If you can't handle the truth, you're living a lie.......
Re: TIMING QUESTION [Re: Big Squeeze] #1351799
12/16/12 01:20 AM
12/16/12 01:20 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Monte stole Wayne's login
Re: TIMING QUESTION [Re: joshking440] #1351800
12/16/12 01:27 AM
12/16/12 01:27 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
LOL.....No, the only Mopar site he goes to is yours!!
Tuning gasoline is all the same...don't matter if it's NA, turbo, blower or nitrous..... Most people over-rocketeer it...If someone really understands NA tuning, nitrous is a breeze.....
I did a LOT of naturally aspirated tuning and fooled with nitrous a little before I called Monte and asked him what it would take to stop by my shop and give me a 1 on 1 nitrous class....after the class I was freaked out that nitrous was NO different than what I'd been doing all along with NA motors...
Re: TIMING QUESTION [Re: Big Squeeze] #1351801
12/16/12 01:23 PM
12/16/12 01:23 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
hmmmmmmmm.....
20 spread 4lbs fuel and 5* total timing
Re: TIMING QUESTION [Re: n20mstr] #1351802
12/16/12 10:08 PM
12/16/12 10:08 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
hmmmmmmmm.....
That doesn't tell me much...I have no idea how many lbs/hour of nitrous you're using....have no idea if you have quench....have no idea if you have a domed piston...have no idea if your carburetor's A/F ratio is dialed in and maxed out...have no idea what the A/f ratio is...Is that someone's starting tune up, or is that where you've come to and it's no longer going any quicker by leaning it out?
4psi isn't necessarily bad but that's getting really close to being low enough to not get good flow to all the nozzles or filling up the spray bars so you can get good/even distribution....
I've seen you post that you have a RacePak...What's the A/F ratio on spray? At what A/F did the motor make max power on nuts? Even with a 20 jet spread and 4psi, if the A/F is in the 10's or 11's you have a long way to go...
Re: TIMING QUESTION [Re: Big Squeeze] #1351803
12/16/12 10:55 PM
12/16/12 10:55 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I think stash master is just posting up random numbers Wayne.
Re: TIMING QUESTION [Re: joshking440] #1351804
12/16/12 11:01 PM
12/16/12 11:01 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
He may be...he may not be... If so, what's the point of this thread?
Re: TIMING QUESTION [Re: Big Squeeze] #1351805
12/16/12 11:47 PM
12/16/12 11:47 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
the point is to see if i can find those missing straps
Re: TIMING QUESTION [Re: n20mstr] #1351806
12/17/12 12:26 AM
12/17/12 12:26 AM
poughquag, NY
440GTX Offline
440GTX  Offline
poughquag, NY
Need to try 70 degrees of timing LOL you are the man tony !!!!!!!!
Re: TIMING QUESTION [Re: n20mstr] #1351807
12/17/12 10:16 AM
12/17/12 10:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Only YOU tony
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: TIMING QUESTION [Re: n20mstr] #1351808
12/17/12 11:26 AM
12/17/12 11:26 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I have mine set at 41 right now in my stock stroke 440 5000 stall 7400 shifts picked up 37 to 39 then more 39 to 41 but I stopped there for this year. Cam, heads, piston design, rpms all affect it so advance till it quits gaining et and maybe more important MPH and maybe take 1 deg back out at that point.
My EA computer dyno program says 41 to 42 so??
Re: TIMING QUESTION [Re: Dodgem] #1351809
12/17/12 01:00 PM
12/17/12 01:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What`s this program you speak of...........I`d like to see what it says about my junk.
Re: TIMING QUESTION [Re: Thumperdart] #1351810
12/17/12 01:50 PM
12/17/12 01:50 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Start off at 50-60 total. Then as you replace parts retard it little by little till you hit the sweet spot. A good rule of thumb if you are replacing big parts retard it more, if small parts less. Good luck with it!!!
If you have any problems there is a guy up in your neck of the woods that uses this methods. I am sure he would be glad to help you out. Lol
Getting old just means you were smarter than some and luckier than others.
Re: TIMING QUESTION [Re: Dodgem] #1351811
12/17/12 04:05 PM
12/17/12 04:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
Me thinks the data inputted on your EA program was for Chevys, not BB Mopars
Re: TIMING QUESTION [Re: Cab_Burge] #1351812
12/17/12 06:44 PM
12/17/12 06:44 PM
Guitar Jones Offline
Mohammad Ghandi can tell you.
Re: TIMING QUESTION [Re: Guitar Jones] #1351813
12/17/12 07:01 PM
12/17/12 07:01 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Let me correct that- MOHELIUS. Mohatama's brother
Re: TIMING QUESTION [Re: actionange] #1351814
12/17/12 09:22 PM
12/17/12 09:22 PM
hemi-itis Offline
hemi-itis  Offline
When this happens,reduce timing by 20 spread
Re: TIMING QUESTION [Re: hemi-itis] #1351815
12/17/12 09:24 PM
12/17/12 09:24 PM
hemi-itis Offline
hemi-itis  Offline
BTW,,,,,,,the straps were in the oil pan
Page 1 of 3 1 2 3
