TIMING QUESTION
#1351796
12/15/12 07:40 PM
12/15/12 07:40 PM
Posts: 4,696 On the parachute mount
n20mstr
How high have you been?
THe higher i go the faster it goes, where should i stop?
....BAD A$$ STREET CAR.....
Re: TIMING QUESTION
[Re: n20mstr]
#1351806
12/17/12 12:26 AM
12/17/12 12:26 AM
Posts: 213 poughquag, NY
440GTX
poughquag, NY
I think stash master is just posting up random numbers Wayne.
He may be...he may not be... If so, what's the point of this thread?
the point is to see if i can find those missing straps
Need to try 70 degrees of timing LOL you are the man tony !!!!!!!!
Re: TIMING QUESTION
[Re: Thumperdart]
#1351810
12/17/12 01:50 PM
12/17/12 01:50 PM
Posts: 5,160 Texas
dannysbee
Texas
Start off at 50-60 total. Then as you replace parts retard it little by little till you hit the sweet spot. A good rule of thumb if you are replacing big parts retard it more, if small parts less. Good luck with it!!! If you have any problems there is a guy up in your neck of the woods that uses this methods. I am sure he would be glad to help you out. Lol
Getting old just means you were smarter than some and luckier than others.
Re: TIMING QUESTION
[Re: Cab_Burge]
#1351812
12/17/12 06:44 PM
12/17/12 06:44 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
Mohammad Ghandi can tell you.
