anyone here set up a pair of 1050,s work on street? #1351770
12/15/12 06:04 PM
12/15/12 06:04 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Can give more detail but motor is a tunnelramed 426 hemi 600ish solid roller with pair of 1050,s 3 circuits
carbs are matched off a race only motor and are decent carbs being rebuilt before
want to be able to drive to local hangout and back home(not a race car)
what's a fair price to have the pair done?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: anyone here set up a pair of 1050,s work on street? [Re: toplescuda] #1351771
12/16/12 01:03 AM
12/16/12 01:03 AM
If there stock Holley original three circuit carbs. they will run really rich at part throttle Really rich like 11.0 to 11.5 AFR or worst You might want to send them to a good custom carb. shop and have them set up for your car for street use I have dyno tested and then raced and modified several Holley three circuit HP 1050 Dominator,9375-2 List #. I had to reduce the intermediate fuel feed and the idle fuel feed to clean them up, I also had to greatly enlarge the intermediate air bleeds to get a bog out of them when foot brake drag racing them before changing the fuel feed circuits Everything mechanical is fixable BTW, what are the list # on both of your carbs? Or are they custom built carbs. built by a carb. shop by someone other than Holley? It can and does makes a difference
Re: anyone here set up a pair of 1050,s work on street? [Re: Cab_Burge] #1351772
12/16/12 02:23 AM
12/16/12 02:23 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Not custome
what's a fair price fora shop set them up?
1971 charger
Re: anyone here set up a pair of 1050,s work on street? [Re: toplescuda] #1351773
12/16/12 09:14 AM
12/16/12 09:14 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
This is probably not the popular response but that's about one dominator carb more than the engine needs. My 605 only uses about 1400cfm at max rpm. It would run much better with a pair of 600's-650's.Dave
Re: anyone here set up a pair of 1050,s work on street? [Re: quickd100] #1351774
12/16/12 12:22 PM
12/16/12 12:22 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
This may be a silly question, but could you unhook one, run just the one? I know the fuel distribution would be crap, but if you are just running to the store or wherever, would it work decent enough??
I agree, though, it is way over kill for a street car. But the looks are great.
Re: anyone here set up a pair of 1050,s work on street? [Re: Dodgeguy101] #1351775
12/16/12 01:44 PM
12/16/12 01:44 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
You could easily make it work. Get a wideband and start tuning.
Will have to jet the transferslots way down, open up the idle air bleed, remove the int air bleeds, jet the int fuel jets down to .020, add power valves, jet the primaries way down. That should do it.
Re: anyone here set up a pair of 1050,s work on street? [Re: Big B] #1351776
12/16/12 03:50 PM
12/16/12 03:50 PM
Missouri
galen Offline
galen  Offline
Missouri
There is a linkage cam for tunnel ram use for the dominator. Changes the progression so you can run more on the front barrels. I use this on mine. I have used BLP from Andy Fs book. They sent me boosters, metering blocks, air bleeds and got me very close. Cannot remember the cost without digging through paperwork.
Re: anyone here set up a pair of 1050,s work on street? [Re: galen] #1351777
12/16/12 09:30 PM
12/16/12 09:30 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Never heard of these cam before
but knowing how the dom. works would see how that it would be helpful in a non all out mode
where can a person find out more about it?
1971 charger
Re: anyone here set up a pair of 1050,s work on street? [Re: toplescuda] #1351778
12/16/12 11:23 PM
12/16/12 11:23 PM
Missouri
galen Offline
galen  Offline
Missouri
Found the box in the garage. 20-6 is the Holley part number on the progressive linkage kit for the older dominators. They give you a little more time on the front barrels then the soft progressive. You may want to call holley and see what linkage came standard in your carbs. The 8896 I used have soft progressive from the factory.
