Page 3 of 4 1 2 3 4
Re: Most embarrasing moments at the track.... [Re: B3422W5] #1350530
12/13/12 07:35 PM
12/13/12 07:35 PM
Why would I share the bad times due to ignorance or incomptence on my part Not me, I'm smarter than that, now BTW, I've done them all plus some you haven't heard of ,yet If you race long enough you will break parts, make mistakes and have some bad times If your a good enough racer the good times will outweigh the bad times, if your goals aren't set to high
Re: Most embarrasing moments at the track.... [Re: Cab_Burge] #1350531
12/13/12 09:46 PM
12/13/12 09:46 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I have had a ton. The bigget one that sticks out in my mine was a specific weekend. I was racing the cuda. I had a gorgeous gf at the time. one night we were "gettin it" in the trailer. first pass next day my whole one piece front end flew off at the shut down. Mind you this had nothing to do with her I told her where to put her hands but earlier in the year a front engine dragster backed into the nose weakening the structure. apparently body guy never fixed that. but back to my epic weekend of fail. I decided to race it without a front end and scoop so I borrowed a friends 340 air cleaner. make a hit and its fine. well rd 1 im doing my burnout and my starting line controller rotated just enough to catch the air cleaned coming out of the burnout box and hangs it wide open. I use the toe hook and im on the brakes but by this time there was a kid sweeping the starting line in front of me. of course i hit him and he goes up on the front of the car. the only thing stopping him was the air filter stud!!! oh and in the process of hitting him I also took out Mark Lyle which is now the NHRA starter. he tried pushing the kid out of the way and my passenger side tire got him. I like to forget about that weekend except the night before!
Re: Most embarrasing moments at the track.... [Re: ChrisJohnston669] #1350532
12/14/12 12:02 AM
12/14/12 12:02 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Back in the early 80's I was changing the engine one night, thrashing to get it together so I could race the next day. I mounted but forgot to bolt down the grill of my 67' GTX. Made a few passes until it fell off at the starting line. I felt like a total tool and went home.
Re: Most embarrasing moments at the track.... [Re: 6PACMAC] #1350533
12/14/12 12:17 AM
12/14/12 12:17 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'm gonna have to remember all you guys so I can avoid an incident
Never had one of those
Re: Most embarrasing moments at the track.... [Re: roadhazard] #1350534
12/14/12 12:30 AM
12/14/12 12:30 AM
SoCal
Brian Hafliger Offline
SoCal
Back in the early 90's, I used to run my 69 Charger with a 440 at Carlsbad raceway.
Last time I went with the old engine, it was really running great...launched like always, shifted into second and BOOM!
I was in such shock that I just coasted allllll the way to the end of the track. Got out, and recieved a huge a$$ chewing by the guy on the tow quad.
I was like, WTF dude...then I saw my 1/4 mile trail of Coolant!! Ohhhhhh $hit...my bad. I must have looked really sick, because after he reamed me, he looked at my car, and said "now next time you blow your $hit up, pull over and stop...and I'm sorry about your loss".
I was so stunned, even after he towed me back, and almost everyone in the pits helped to push the car back on the trailer I remember telling my dad the jerk that towed me back just chewed my butt left and right and I was really mad at him for being so inconsiderate because I just lost my prized possession!
Then my Dad told me that the whole time I was in the pits the track was shut down because of my neglegance to pull over and stop.
As I looked around in the pits, I could see lost of glaring eyes looking my way...so we left promptly!
Was really embarrasing for me, and I'm sure for my Dad...love you dad!! Ha ha
Brian Hafliger
Re: Most embarrasing moments at the track.... [Re: Brian Hafliger] #1350535
12/14/12 12:59 AM
12/14/12 12:59 AM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
First time down the track with my car, forgot to latch the trunk. It comes up fast when you hit the brakes hard.
Then next time at the track, I decide to remove the air cleaner, hoping to go quicker. What I forgot was the gasket under the air cleaner. Burn out sucks the gasket into carb, and jams in the throttle blades. 3500+ rpm idle,shut it down and got pushed out, DUH!
Suprised I stuck with it after those two first outings
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: Most embarrasing moments at the track.... [Re: 73swinger] #1350536
12/14/12 10:03 AM
12/14/12 10:03 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I did that on my Dakota, doing testing to see if my air cleaner was creating any restriction in my intake path (used a datalogger to record Manifold pressure with Throttle Position. figured if my air filter was creating a restriction, my MAPs would indicate a vacuum in the manifold.
anyway, on the testing with the air cleaner off, I forgot the gasket as well! only I was on the street!
during the WOT runs out in the sticks, nothing went wrong. when did the gasket suck into the TB blades? yea, in town. with traffic. At least I hadn't gone WOT in town, and it only jammed at about 3/8 throttle, so I quickly stepped on the clutch, let the RPM climb, and it was also "idling" at about 3600 rpm. pulled over, shut it off, popped the hood and saw what happened.
**Photobucket sucks**
Re: Most embarrasing moments at the track.... [Re: 70Cuda383] #1350537
12/14/12 10:11 AM
12/14/12 10:11 AM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
Ah, I've posted this before on this forum. I don't drag race, I truck pull a 4x4 truck. I hooked to the sled one night and left the line, thought it was odd the shift light came on, but it was running great. I spun out at the big end with the shift light on. The crowd looked a little puzzled and was told that only the back tires spun.......I forgot to shift it into 4wd.....I was disgusted, I can't remember if I got 2nd or 3rd place. I would have won if I was in 4wd.......
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Most embarrasing moments at the track.... [Re: MMiller] #1350538
12/14/12 12:38 PM
12/14/12 12:38 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
one time i'm racing my daytona, (stock turbo nothing fast) i'm racing this white mustang, I am spotted a lot.
take off, get going, look around dont see him, look in the mirror and i see a white mustang sitting on the starting line. I lift so i dont break out just in time to see the white mustang in my blind spot zip past me for the win.
Re: Most embarrasing moments at the track.... [Re: B3422W5] #1350539
12/14/12 01:35 PM
12/14/12 01:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I went to Frank Haleys drag school back in the early nintys.
It helped me a ton and I didn't have any embarassing moments at the track...until I wrecked my dragster on national TV during round one on Sun morning at the NHRA nats in June in Columbus Ohio. That sucked.
Re: Most embarrasing moments at the track.... [Re: plasticfantastic] #1350540
12/14/12 01:55 PM
12/14/12 01:55 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
There are just too many of those Mustangs.... they all look alike.
Re: Most embarrasing moments at the track.... [Re: Challenger 1] #1350541
12/14/12 02:01 PM
12/14/12 02:01 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I was there that day. My wife and I were in the pits when that happened and Connie Kalitta came rushing toward us to see what happened. Connie kinda has funny eyes and as he was rushing toward us he sucked up a big hocker and was about to spit it out. His eyes were looking one direction and he spit in the other direction almost spitting on the ex wife.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Most embarrasing moments at the track.... [Re: B3422W5] #1350542
12/14/12 02:20 PM
12/14/12 02:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
On my very first pass at L.A.C.R.,I pulled right up to tree and was wondering why they didn`t start back farther so your neck wouldn`t get all cramped up.............. I`m sure some creative things were being said about me in the stands.............
Re: Most embarrasing moments at the track.... [Re: Thumperdart] #1350543
12/14/12 02:24 PM
12/14/12 02:24 PM
fresno ca
mikeysmopars Offline
fresno ca
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Most embarrasing moments at the track.... [Re: gregsdart] #1350544
12/16/12 12:27 AM
12/16/12 12:27 AM
MN
hemidup Offline
hemidup  Offline
MN
Forgot the hood pins twice, timed out once, fogot about the extra 6 gallons of fuel and tool bag in the trunk once, but the worst was in the final's at Monster Mopar Weekend when my partner opened up the door and said "Whatever you do don't red light" After nailing the tree round after round to get there I cut like a .400 light on a sportsmans tree in the final round....We had words afterwards. lol
Jerry Williams.
Re: Most embarrasing moments at the track.... [Re: hemidup] #1350545
12/16/12 12:39 AM
12/16/12 12:39 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
I'm embarrased bout every 3rd light, but one time at pacemakers, did a burnout a made a hard stop just before the line then a missing and melted flashlight went sliding up the track about 15ft. I was wondering where that flashlight had gone
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Most embarrasing moments at the track.... [Re: hemidup] #1350546
12/16/12 12:49 AM
12/16/12 12:49 AM
PA.
"Little"John
"Little"John
PA.
When you have raced for 35+ years there are lots of these embarrassing moments so I'll go with my last one that happened this year in the box class. I was on a roll hitting the tree pretty good all night and made it to the final. The other driver asked if I wanted to split the money in the final with an extra 50 dollars going to the winner. I didn't really want to but finally agreed. Rule number one when using a box. REMOVE all numbers from the round before. In the semi's I raced a car 2 seconds slower than me and in the final I had a car 1 second faster. He got one heck of a head start and needless to say took the win. I still made out pretty good but he was standing in the winners circle with the trophy.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Most embarrasing moments at the track.... [Re: pittsburghracer] #1350547
12/16/12 01:16 AM
12/16/12 01:16 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
My best happened when I was about 19....my car is a 4-speed and I didn't have a rev limiter so I bought a Mallory tach with built in rev limiter (had a knob you twist to set the rpm at which it cuts out the motor)...I installed it and drove it on the street for a few weeks and one day as I'm cruising down the highway I look at the tach and it's reading double what it should be ....after about 1 mile it goes back to reading normal and doesn't act up again....
So, about a month later I decide to take my car to the track and run it for the first time with my fairly new 438" 383....On my first pass I stage, bring the motor up to about 3K, dump the clutch and it goes about 5 feet and the engine starts cutting out and the whole car starts shaking like crazy!!! Rearview mirror is bouncing around....glovebox opens...I look at the tach and it shows 6K but I know the motor isn't that high....I remember that day when it read double and so I reach up and crank the knob all the way to the right to raise the rpm limit so it'll stop cutting out and I finish the run with a mid 13 second pass....
Imagine being WOT with a stick car, clutch pedal out and against the chip at 3,000rpm....I was freaked out!!!!!
When I got home I pulled the tach off the car and threw it in the trash and haven't had a tach in a car ever since....
If you can't handle the truth, you're living a lie.......
Re: Most embarrasing moments at the track.... [Re: Big Squeeze] #1350548
12/16/12 02:16 AM
12/16/12 02:16 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
about 10 years ago, i had just got my 383 barracuda running. took it to the track a few times to tune out the bugs. Finally got my slicks, had been running street tires. Get them mounted and get to the track enter the water box and get in it. Car revs to the moon but does not move. I start playing with my shifter, nothing. I get it in reverse and back out of the box. I take it back to the pits thinking i had destroyed my trans... My friends come over and ask what happened. I told them it just free revved, and i think my trans is messed up.
My buddy said my tires sure were spinning a lot for my tranny to be bad. first time i had a set of slicks in the water, they sure are slippery. LOL, no trans issues just driver issues.
Re: Most embarrasing moments at the track.... [Re: 8urvette] #1350549
12/16/12 10:17 AM
12/16/12 10:17 AM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
One day (several years ago) I raced my way into the semifinals and was nervous as hell. For some reason I was concerned my water temp was a little high and that I need to cool the engine down just a little. The decision was made to run the electric fan until the burn out was complete. Pulled up to the starting line and lit the 1st bulb, reached over to shut off the fan but shut off the electric fuel pump instead. I learned that day that my car could Launch and pull through 1st gear with just the fuel in the carb.
Page 3 of 4 1 2 3 4
