Re: Most embarrasing moments at the track....
[Re: sixpackgut]
#1350510
12/13/12 12:27 PM
12/13/12 12:27 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
burnout in reverse
Me too.... or how about make the first run and then coming back to the pits, the car dies. So I get out and pull the hood, no fuel, turn the pump on get some pressure so I set the hood back on and jump in fire it up and try to make it back, oh crap I forgot the hood pins as the hood lifts and flips over the top of the car about 20ft in the air. I felt really really dumb.... Oh and I forgot to put gas in it, thats why it wouldn't run....
[Re: cudadoug]
#1350511
12/13/12 12:42 PM
12/13/12 12:42 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Gee, let's see...
Running out of gas on the return road and causing a back up.
Forgetting the hood pins after tech. Man those 6 bbl scoops catch alot of air!
Leaving the foam in the scoop for a run.
Going. 002 to a. 150-something light. Being so excited I was going to my first final not paying attention...11.41 on a 11.43 dial.
Going -001 red and going 10.430 on a 10.43 dial.
Forgetting to put the shifter in park and watching your call roll backwards off the trailer after getting out.
I've done that last on your list too. Back in the 80's I got to final. We both stage. I'm waiting on the tree to come down. At some point the thought goes through my mind I'm late. So I just left. I got the big red eye. What a DA I was.
[Re: dustergirl340]
#1350513
12/13/12 01:23 PM
12/13/12 01:23 PM
Triple Threat
Renton Washington
Semi finals, Thanksgiving Bracket nationals at Vegas last season. Whole load of family and friends are back home watching the live stream of the race. Ran out of gas on the starting line ....... other guy goes -.001 I broke the beam, got pushed off the starting line, borrowed some gas for the final and won the race! .00X to his .300, lift way early and coast out the back, go .001 under taking a train length. .00X to his .100, Give it back by .0004
[Re: cudadoug]
#1350514
12/13/12 01:37 PM
12/13/12 01:37 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
"Forgetting the hood pins after tech. Man those 6 bbl scoops catch alot of air!" Best I've seen was a 69rr 6pak hood go about 100 ft in the air. To accomplish that I think the angle of the car has to be just right, to keep it in place till after the 330 mark
[Re: B3422W5]
#1350516
12/13/12 02:08 PM
12/13/12 02:08 PM
Posts: 119 SE VA
hemibee69
SE VA
Am I the only one to forget put the cap back on the fuel cell? Coming out of the burnout box and race gas is pouring out of the trunk, easy fix but cost the race. JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly) 1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph 1970 Challenger SE 383 4 bbl A/C PB PS Leather 1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
[Re: CompWedgeEngines]
#1350519
12/13/12 02:41 PM
12/13/12 02:41 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Well lets see. I have traveled 1100 miles and forgot to turn the air bottle on...Or this one, when we had the Belvedere it had a stock gas tank. Left the fuel cap off once and got chased down by the firetruck all the way through the shut down area and return road. nothing exctiting thats about it for me.
[Re: sam64]
#1350525
12/13/12 03:56 PM
12/13/12 03:56 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Went to hit 4th, which should be a quick and easy straight back pull on the shifter, but after a night of beating on it, my shifter handle and adapter piece I made to fit the B-body pistol grip into the Dakota, had come a tad loose, so the handle was sliding on the shifter some.
Instead of 4th, I put it in 2nd, at about 75mph. skidded the tires a good 20-30 feet, RPM through the roof. coasted out the back end. down the return road, and straight for the gate. (it was getting late anyway, and the track was getting slick)
**Photobucket sucks**
[Re: mikeysmopars]
#1350526
12/13/12 04:03 PM
12/13/12 04:03 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
At a little track in Lawrenceburg, Tn (old U.S.43) about 1985, I do a burn out across the start line (OK to do at this short track), back up and stage carefully. The starter taps on the window and motions me to back up. Thats when I realized that I had staged with the back tires. I had a red helment on and my face matched it for a while.
Just about as bad, maybe worse, 2010 at Bristol, I started running two classes, 1/8 mile Pro and 1/4 mile Sportsman, same car/same day. First day I did this, I went to the finals in both classes (won 1/4 mile, red light away 1/8 mile). The next week I'm rollin' along through the rounds again and about rd 4 of the 1/4 mile race, I draw someone thats way quicker than me (me 10.90, him 9.90). Up until now all of my 1/4 mile races have been against slower or equal cars (everything either beside me or in front of me). I get near the 1/8 mile mark and look back, this guy is WAY behind and ain't gonna get there. I start whomp, whomp, whomp and my win light doesn't come on, then he BLOWS by me and his win light doesn't come either. At least for about 3 seconds, THEN his light comes on. I'm like, What the ???. All of a sudden, I realize what I did. The butt chewing I got that day didn't come anywhere close to the one I got about 3 weeks later, when I did it again. The 80 mile trip home that day seemed more like 180 miles.
At least I've never ran out of fuel on the track. Yet.
Brian Dunnigan
[Re: '72CudaRacer]
#1350527
12/13/12 04:08 PM
12/13/12 04:08 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Was at Tri-State track, this was before I installed the fuel cell, stock tank and forgot to twist the fuel cap and dumped a couple gallons of race fuel at the starting line and down the track. Found the cap behind the plate after the ticket guy says i was dropping fluid.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: B3422W5]
#1350529
12/13/12 06:28 PM
12/13/12 06:28 PM
Posts: 100 West Virginia USA
Palindrome Cuda
West Virginia USA
Yep, the gas deal. I am headed to the staging lanes to tech. My son says "we better put in some gas we don"t have enough to make a full pass" and I said " " I'm just going to tech and right back" got stuck in the lanes and had to make the pass. I remembered his words just as I crossed the traps as I coasted to the return road. I had to call him to bring the gas,I told him he was wrong that I did make it to the traps. He still gives me the razz about that. He drove the car back to the pits,made me walk. I told his mother,no help there !!! Fun times.
Bob George Racing sponsored '67 'cuda
9.96 @ 131mph
