Most embarrasing moments at the track....
#1350490
12/12/12 07:42 PM
12/12/12 07:42 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I have had so many its kinda hard to pick just one, but i will anyhow.. Few years ago i was at the IHRA Northern Nationals at US131, was a huge event back then, 10 years ago. At that time my car was running 10.50 ish. Had w5 heads, and a dinky flat tappet cam in it then, and stock gas tank with 3/8 pickup and Holley Blue pump. Over the weekend we got three time trials, car was running good, and i was ready for action when they called us up for 1st round right after the night of fire show. I come around the corner to a full house and am amped up. I look over and see i have an 11.50 Firebird in the first round. Have raced the guy 3 or 4 other times and he has always gotten the best of me....but tonight i am gonna get him We stage, and i take off after him, feeling like i had a good light( i did, 509 to his 540 something) I am reeling him him, put the car in high gear...and splat..it dies out on me as i see him driving off in the distance Let off, get back in it, picks up, stumbles again, so i just coast out For the first and only time ever, i showed up to the starting line with about 3/8 of a tank of gas and stupid me the pickup uncovered. I immediately the next week put a cell in the car, but the damage was done. Doug, the guy i was racing, came over to my pits and says" Hey, what happened, i thought you had me"...Me..."Doug, I ran out of friggin gas"
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Most embarrasing moments at the track....
[Re: VernMotor]
#1350495
12/12/12 10:09 PM
12/12/12 10:09 PM
Posts: 4,979 new jersey usa
11secdart
new jersey usa
First Round .. Division One Bracket Finals back in the 80s at Maple Grove, I pulled into the burnout box.. then was backed out as something happened down track. When they started us back up I left the e brake on and the car would`t move much, Rather than put it back in park I put it in neutral and put the e brake on. I heard about that for awhile. If you race long enough you acquire quite a few " embarrassing moments".
[Re: J_BODY]
#1350497
12/12/12 11:42 PM
12/12/12 11:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
2nd weekend after I built my car... pulled to the line and put the boot to the fast pedal and as soon as it launched the throttle cable broke... get back to the pits and fix it(enough to get through the day) and head back up the the lanes.. sitting in the burnout box they have a short hold on the track so I shut down... couple minutes later we get the fire them up sign.. do a short burnout and pull to the line and the light starts.. I hit the pedal again.. as soon as the car moves.. it quit... forgot to turn the pump on... 2 times in 1 day it didnt make it off the line... the starter said... why dont you come back when you get it fixed up... then as they were getting ready to push me off I remembered the pump.. fired up and ran it down the track..... and loaded it up.. I was too embarrassed to try again
[Re: dvw]
#1350501
12/13/12 12:49 AM
12/13/12 12:49 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Didn't happen to me but we were watching some guys on a test & tune knight and an older gentleman rolled up in his new mustang and rolled streight through the water box to the beams which he blew through and had to be backed up and staged. He got both bulbs lit and started power breaking it. As soon as both cars were staged the lights dropped and he was out of shape right away, Never lifted even when he backed it in the wall. I felt bad for him.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#1350502
12/13/12 02:38 AM
12/13/12 02:38 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
"gettin it" with the gf in the enclosed trailer when the racer next to me wanted to borrow a distributor wrench face in palm ya gon have dat lol
[Re: B3422W5]
#1350506
12/13/12 12:15 PM
12/13/12 12:15 PM
Posts: 2,273 Greenville, South Carolina
BBLM23
I race a K-car... and I have another unfinished K-car race car...
First points race snapped a ball off the carb linkage on the launch, idled down the track.
First license pass took most of the teeth off the 8 3/4 ring gear, idled down the track.
Finally started started going rounds after a convertor swap. First time shot the next week I break an axle in the 8 3/4, idled down the track.
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: BBLM23]
#1350508
12/13/12 12:18 PM
12/13/12 12:18 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Walter, Have you ever thought of dialing your car based on what it runs idling down the track? Your have a good log book of passes to compare it to....
RIP Monte Smith
[Re: CompWedgeEngines]
#1350509
12/13/12 12:21 PM
12/13/12 12:21 PM
BBLM23
It's consistent idling because the clocks time out!
