Re: Most embarrasing moments at the track....
[Re: ChrisJohnston669]
#1350532
12/14/12 12:02 AM
12/14/12 12:02 AM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
Back in the early 80's I was changing the engine one night, thrashing to get it together so I could race the next day. I mounted but forgot to bolt down the grill of my 67' GTX. Made a few passes until it fell off at the starting line. I felt like a total tool and went home.
[Re: roadhazard]
#1350534
12/14/12 12:30 AM
12/14/12 12:30 AM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
Back in the early 90's, I used to run my 69 Charger with a 440 at Carlsbad raceway. Last time I went with the old engine, it was really running great...launched like always, shifted into second and BOOM! I was in such shock that I just coasted allllll the way to the end of the track. Got out, and recieved a huge a$$ chewing by the guy on the tow quad. I was like, WTF dude...then I saw my 1/4 mile trail of Coolant!! Ohhhhhh $hit...my bad. I must have looked really sick, because after he reamed me, he looked at my car, and said "now next time you blow your $hit up, pull over and stop...and I'm sorry about your loss". I was so stunned, even after he towed me back, and almost everyone in the pits helped to push the car back on the trailer I remember telling my dad the jerk that towed me back just chewed my butt left and right and I was really mad at him for being so inconsiderate because I just lost my prized possession! Then my Dad told me that the whole time I was in the pits the track was shut down because of my neglegance to pull over and stop. As I looked around in the pits, I could see lost of glaring eyes looking my way...so we left promptly! Was really embarrasing for me, and I'm sure for my Dad...love you dad!! Ha ha
Brian Hafliger
[Re: Brian Hafliger]
#1350535
12/14/12 12:59 AM
12/14/12 12:59 AM
Posts: 864 St Paul MN
73swinger
St Paul MN
First time down the track with my car, forgot to latch the trunk. It comes up fast when you hit the brakes hard. Then next time at the track, I decide to remove the air cleaner, hoping to go quicker. What I forgot was the gasket under the air cleaner. Burn out sucks the gasket into carb, and jams in the throttle blades. 3500+ rpm idle,shut it down and got pushed out, DUH! Suprised I stuck with it after those two first outings
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: 73swinger]
#1350536
12/14/12 10:03 AM
12/14/12 10:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I did that on my Dakota, doing testing to see if my air cleaner was creating any restriction in my intake path (used a datalogger to record Manifold pressure with Throttle Position. figured if my air filter was creating a restriction, my MAPs would indicate a vacuum in the manifold.
anyway, on the testing with the air cleaner off, I forgot the gasket as well! only I was on the street!
during the WOT runs out in the sticks, nothing went wrong. when did the gasket suck into the TB blades? yea, in town. with traffic. At least I hadn't gone WOT in town, and it only jammed at about 3/8 throttle, so I quickly stepped on the clutch, let the RPM climb, and it was also "idling" at about 3600 rpm. pulled over, shut it off, popped the hood and saw what happened.
**Photobucket sucks**
[Re: 70Cuda383]
#1350537
12/14/12 10:11 AM
12/14/12 10:11 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
Ah, I've posted this before on this forum. I don't drag race, I truck pull a 4x4 truck. I hooked to the sled one night and left the line, thought it was odd the shift light came on, but it was running great. I spun out at the big end with the shift light on. The crowd looked a little puzzled and was told that only the back tires spun.......I forgot to shift it into 4wd.....I was disgusted, I can't remember if I got 2nd or 3rd place. I would have won if I was in 4wd.......
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: gregsdart]
#1350544
12/16/12 12:27 AM
12/16/12 12:27 AM
Posts: 833 MN
hemidup
MN
Forgot the hood pins twice, timed out once, fogot about the extra 6 gallons of fuel and tool bag in the trunk once, but the worst was in the final's at Monster Mopar Weekend when my partner opened up the door and said "Whatever you do don't red light" After nailing the tree round after round to get there I cut like a .400 light on a sportsmans tree in the final round....We had words afterwards. lol
Jerry Williams.
[Re: hemidup]
#1350545
12/16/12 12:39 AM
12/16/12 12:39 AM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
I'm embarrased bout every 3rd light, but one time at pacemakers, did a burnout a made a hard stop just before the line then a missing and melted flashlight went sliding up the track about 15ft. I was wondering where that flashlight had gone
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: hemidup]
#1350546
12/16/12 12:49 AM
12/16/12 12:49 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When you have raced for 35+ years there are lots of these embarrassing moments so I'll go with my last one that happened this year in the box class. I was on a roll hitting the tree pretty good all night and made it to the final. The other driver asked if I wanted to split the money in the final with an extra 50 dollars going to the winner. I didn't really want to but finally agreed. Rule number one when using a box. REMOVE all numbers from the round before. In the semi's I raced a car 2 seconds slower than me and in the final I had a car 1 second faster. He got one heck of a head start and needless to say took the win. I still made out pretty good but he was standing in the winners circle with the trophy.
[Re: pittsburghracer]
#1350547
12/16/12 01:16 AM
12/16/12 01:16 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
My best happened when I was about 19....my car is a 4-speed and I didn't have a rev limiter so I bought a Mallory tach with built in rev limiter (had a knob you twist to set the rpm at which it cuts out the motor)...I installed it and drove it on the street for a few weeks and one day as I'm cruising down the highway I look at the tach and it's reading double what it should be ....after about 1 mile it goes back to reading normal and doesn't act up again.... So, about a month later I decide to take my car to the track and run it for the first time with my fairly new 438" 383....On my first pass I stage, bring the motor up to about 3K, dump the clutch and it goes about 5 feet and the engine starts cutting out and the whole car starts shaking like crazy!!! Rearview mirror is bouncing around....glovebox opens...I look at the tach and it shows 6K but I know the motor isn't that high....I remember that day when it read double and so I reach up and crank the knob all the way to the right to raise the rpm limit so it'll stop cutting out and I finish the run with a mid 13 second pass.... Imagine being WOT with a stick car, clutch pedal out and against the chip at 3,000rpm....I was freaked out!!!!! When I got home I pulled the tach off the car and threw it in the trash and haven't had a tach in a car ever since....
If you can't handle the truth, you're living a lie.......
