Need help with a few codes on fender tag #1349567
12/11/12 02:30 PM
12/11/12 02:30 PM
Northeast
V
VincentVega Offline OP
V
Northeast
Car is a 1978 Plymouth. There are three codes in red I can't figure out. Could anyone please help? Thanks in advance
Got my info, image removed. thanks for the help
Re: Need help with a few codes on fender tag [Re: VincentVega] #1349568
12/11/12 03:52 PM
12/11/12 03:52 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
the item before the U is more like a "*" asterisk or star. It's not uncommon on tags from Lynch Road built cars. I don't know that it carries any significance other than maybe a place holder. 28 = 28" radiator. F42 = additional dome light.
Looks similar to a tag from a cop car. Is it?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Need help with a few codes on fender tag [Re: 69CoronetRT] #1349569
12/11/12 04:04 PM
12/11/12 04:04 PM
Northeast
V
V
Northeast
It is, E68 A38. I have two of them actually, although the tags are still on the other. That's a project for later, after I make the mistakes on the first one here Thanks so much! this was very helpful!
btw, it IS a Lynch Road car. Good info! Car was built in early June '78 (and interesting is that they made running changes to these cars on 6/1). Probably one of the last big block cars built ever.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Need help with a few codes on fender tag [Re: VincentVega] #1349570
12/11/12 04:23 PM
12/11/12 04:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
.... Car was built in early June '78 (and interesting is that they made running changes to these cars on 6/1). Probably one of the last big block cars built ever.
What were the running changes??
Re: Need help with a few codes on fender tag [Re: autoxcuda] #1349571
12/11/12 04:41 PM
12/11/12 04:41 PM
Northeast
V
V
Northeast
sheet metal for one. dash for another. I've been living out of the parts catalog for the last few months, cross checking and collecting information. Just an example:
Listed here is a pretty important piece. It never says why they changed, but I thought it was very unusual they would bother to do this so much on a line they knew was ending.
