How much HP...9.90s...3800 lbs... #1349411
12/11/12 01:35 AM
12/11/12 01:35 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
How much "true" HP is needed to push 3800 lbs to 9.90s?
Yeah, I know it takes a sorted chassis, but I do believe mine is finally dang close.
Looking for real world experience....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: How much HP...9.90s...3800 lbs... [Re: Von] #1349412
12/11/12 01:37 AM
12/11/12 01:37 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
750ish in my 3850 lb boat
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: How much HP...9.90s...3800 lbs... [Re: Von] #1349413
12/11/12 02:19 AM
12/11/12 02:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
720HP if you are set up right... if your not set up
right a 1000HP wont do it
Re: How much HP...9.90s...3800 lbs... [Re: Von] #1349414
12/11/12 09:12 AM
12/11/12 09:12 AM
gregsdart Offline
gregsdart  Offline
Your question got me to thinking about a reasonably cheap way to get to that power level. So, look for the post on the flat tappet B1 question! I see on my Computec it says 775 hp to get to 9.90 at 3800. 720, 750, 775, none are easy to come by cheap. But just maybe,,,,,,,,,,,
Re: How much HP...9.90s...3800 lbs... [Re: gregsdart] #1349415
12/11/12 10:00 AM
12/11/12 10:00 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My 72 cuda weighed in at 3780 with me in it, 36 inch ladder bars, 499 with J&E 14.85 to 1 compression, Indy 440-1 cast heads, comp roller, 5500 T/A converter, trans brake 727 with 277 first gear, dana 60 456 rear, 14.5x32 goodyears.
1.31 to 1.33 60 ft, 9.89 at 134 mph. Certified Chassis Engine Dyno'ed at Meaux's Race head service. 787 hp 590 tq. shift at 7200
This was my old set up. A lot of changes since then.
My dart is a 511 B1 original, tube chassis car, 2 spd and 456 dana. I run a comp roller in it, shifting at 8000. Still working on it and tuning.
Re: How much HP...9.90s...3800 lbs... [Re: MR_P_BODY] #1349416
12/11/12 05:05 PM
12/11/12 05:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What are you up too Von ? Ron
Re: How much HP...9.90s...3800 lbs... [Re: Von] #1349417
12/11/12 06:35 PM
12/11/12 06:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
easy build a 10.90 engine and toss 12lbs of boost on it... done. I think by what i've seen on those handi-dandi HP calculators one would need about 720 RWHP to move frieght like ours....
Coming soon!!!!
Re: How much HP...9.90s...3800 lbs... [Re: Mr.Yuck] #1349418
12/11/12 07:02 PM
12/11/12 07:02 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
The other guys are getting it done with 650RWHP.
http://www.youtube.com/watch?v=siqUezuWSyE
A new iron curtain drawn across the 49th parallel
Re: How much HP...9.90s...3800 lbs... [Re: Von] #1349419
12/11/12 08:01 PM
12/11/12 08:01 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
This website is pretty fun to play with:
http://vexer.com/automotive-tools/1-4-mile-ET-HP-MPH-calculator
According to it, 775 hp is needed.
Re: How much HP...9.90s...3800 lbs... [Re: 383man] #1349420
12/11/12 11:20 PM
12/11/12 11:20 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Dreamin!!
Re: How much HP...9.90s...3800 lbs... [Re: 67autocross] #1349421
12/12/12 12:47 AM
12/12/12 12:47 AM
Sounds like the trans is about ready to disintergrate on the 1-2 shift something is wrong
