How much HP...9.90s...3800 lbs...
#1349411
12/11/12 01:35 AM
12/11/12 01:35 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
How much "true" HP is needed to push 3800 lbs to 9.90s? Yeah, I know it takes a sorted chassis, but I do believe mine is finally dang close. Looking for real world experience.... Thanks
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: How much HP...9.90s...3800 lbs...
[Re: Von]
#1349413
12/11/12 02:19 AM
12/11/12 02:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
720HP if you are set up right... if your not set up right a 1000HP wont do it
[Re: Von]
#1349414
12/11/12 09:12 AM
12/11/12 09:12 AM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Your question got me to thinking about a reasonably cheap way to get to that power level. So, look for the post on the flat tappet B1 question! I see on my Computec it says 775 hp to get to 9.90 at 3800. 720, 750, 775, none are easy to come by cheap. But just maybe,,,,,,,,,,,
[Re: gregsdart]
#1349415
12/11/12 10:00 AM
12/11/12 10:00 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
My 72 cuda weighed in at 3780 with me in it, 36 inch ladder bars, 499 with J&E 14.85 to 1 compression, Indy 440-1 cast heads, comp roller, 5500 T/A converter, trans brake 727 with 277 first gear, dana 60 456 rear, 14.5x32 goodyears.
1.31 to 1.33 60 ft, 9.89 at 134 mph. Certified Chassis Engine Dyno'ed at Meaux's Race head service. 787 hp 590 tq. shift at 7200
This was my old set up. A lot of changes since then.
My dart is a 511 B1 original, tube chassis car, 2 spd and 456 dana. I run a comp roller in it, shifting at 8000. Still working on it and tuning.
[Re: 383man]
#1349420
12/11/12 11:20 PM
12/11/12 11:20 PM
Von
NE Oklahoma
What are you up too Von ? Ron
Dreamin!!
