Widest tires on Stock Cordoba. #1348702
12/09/12 09:28 PM
12/09/12 09:28 PM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
What would be a good tire combo for my 79 Cordoba. Its stock right now I want some fat tires out back and Im thinkin some 235/70/15s up front. What would be the best wide tire to match the 235/70s up front?
Re: Widest tires on Stock Cordoba. [Re: 71Polara383] #1348703
12/09/12 10:20 PM
12/09/12 10:20 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I had a 76 Charger with the stock 15x6.5 Rallyes. 235-60's looked really good all the way around.
Re: Widest tires on Stock Cordoba. [Re: burdar] #1348704
12/09/12 10:34 PM
12/09/12 10:34 PM
scratchnfotraction Offline
I had a 76 Daytona Charger SE with 7" rim 235/70/15 fronts 10" wide keystone rims with N-50s on the back of mine in 82.
Re: Widest tires on Stock Cordoba. [Re: scratchnfotraction] #1348705
12/10/12 05:20 PM
12/10/12 05:20 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I had 235/60 fronts and 255/60 rears on my 77 Doba with Road wheels (I think those wheels are 6.5" wide?).
Filled wheelwells nicely.
Re: Widest tires on Stock Cordoba. [Re: Fury Fan] #1348706
12/11/12 10:24 AM
12/11/12 10:24 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
don't know for sure, but I fit 255/50R17's on my M body, I would think the larger B could fit the same size tire on the front (which is dimensionally the same as a 255/60R15)
probably can get like a 275/60R15 or a 295 section...
2017 Grand Cherokee Overland
Re: Widest tires on Stock Cordoba. [Re: patrick] #1348707
12/11/12 01:44 PM
12/11/12 01:44 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
I had 285s on the back and there was still room to go.
I've seen 295s, and I'm sure 305s will fit.
1971 Challenger
Re: Widest tires on Stock Cordoba. [Re: cudazappa] #1348708
12/11/12 02:49 PM
12/11/12 02:49 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
I had a Magnum once w/I believe 295/60/15's and room to spare.
Fronts can almost do the 275, slight rub lock to lock
Keep in mind if your springs are sagging, you might consider changing them or airshocks?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Widest tires on Stock Cordoba. [Re: Magnumguy] #1348709
12/12/12 01:52 PM
12/12/12 01:52 PM
pa
ramman16248 Offline
ramman16248  Offline
pa
15x8 Cragars on rear, 15x7 on front. Tires are 275/60/15 rear and 235/60/15 on front. I added air shocks to give it a little rake.
http://www.flickr.com/photos/8240930@N04/4443240790/
