Re: Widest tires on Stock Cordoba.
[Re: Fury Fan]
#1348706
12/11/12 10:24 AM
12/11/12 10:24 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
don't know for sure, but I fit 255/50R17's on my M body, I would think the larger B could fit the same size tire on the front (which is dimensionally the same as a 255/60R15)
probably can get like a 275/60R15 or a 295 section...
[Re: patrick]
#1348707
12/11/12 01:44 PM
12/11/12 01:44 PM
Posts: 801 central CT
cudazappa
central CT
I had 285s on the back and there was still room to go.
I've seen 295s, and I'm sure 305s will fit.
1971 Challenger
[Re: cudazappa]
#1348708
12/11/12 02:49 PM
12/11/12 02:49 PM
Posts: 10,640 S.E.Ohio
Magnumguy
S.E.Ohio
I had a Magnum once w/I believe 295/60/15's and room to spare.
Fronts can almost do the 275, slight rub lock to lock
Keep in mind if your springs are sagging, you might consider changing them or airshocks?
